It is currently Sat Dec 27, 2025 9:11 pm
PostPosted: Sat Aug 23, 2003 7:59 pm
Hey,
well i'm finally moving into porting from bowlwork.. my only quesion is HOW to get at the center of the ports right where the turn is ?? :shock: i'm using an airgrinder and some small grinding stones, i've tried longer ones and i've tried shorter ones and there is just pain and simple no way i can get in there :shock: i'm scared of screwing up the seats even though they're only "roughed" in... any tips on this will be greatly appriciated saying i have to get this baby back to the shop to get finished up.... i really need to find a way instead of going at it with sandpaper (hand sanding..)
thanks for the help
Justin
PostPosted: Sun Aug 24, 2003 7:06 pm
I have some long bit extensions that I use on my die grinder. I don't remember where I got them, though. I'll try to track down a source and let you know, if no one else knows right off.
"DW"
If it ain't broke, fix it!
PostPosted: Sun Aug 24, 2003 10:21 pm
Hmm, dremels have this flexible snake like deal you can attach to the tool and attach the bit to the end of the snake.
PostPosted: Sun Aug 24, 2003 10:30 pm
I've used a dremel for fine finish work, but they're slow goin' takin' out meat...
"DW"
PostPosted: Mon Aug 25, 2003 9:09 am
Dremels are the wrong tool to use for cast iron porting.. They're decent on aluminum, though. A preferable tool for iron would be a high-speed electric die grinder with a speed adjustment.
PostPosted: Mon Aug 25, 2003 9:43 am
I've used a dremel for fine finish work...
"DW"
PostPosted: Mon Aug 25, 2003 1:22 pm
My air powered die grinder with 4 inch lon shank carbige cutters is the tool of choice for porting.
I think I will get a 6 inch long shank oval cutter the next time I purchase one, that will give me a little extra room when working deep inside the ports.
The cutters in the can, at the bottom of this shot have 4-inch long shanks:
http://www.dutra.org/pictures/engine/pa ... rtwork.jpg
