It is currently Wed Jun 03, 2026 1:54 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
PostPosted: Thu Mar 31, 2011 2:25 pm
I was always under the impression that the A/C pumps had less fins on the impeller specifically to move coolant slower so it would pick up more heat while in the motor. By product of that was less cavitaion.
Summit used to sell the sheet metal plates to put on the back of impellers too. They were a couple bucks.
PostPosted: Thu Mar 31, 2011 2:43 pm
The water pumps for LA engines with AC had fewer vanes, but the water pump pulley was also smaller so the pump and fan were driven faster.
PostPosted: Fri Apr 01, 2011 5:44 am
I think I would be cutting vanes off the water pump, or reducing their area, if anything.
PostPosted: Fri Apr 01, 2011 9:37 am
PostPosted: Fri Apr 01, 2011 11:27 am
I have a tangential question to ask: what are the track regulations on what you're allowed to run in the cooling system? Do they make you run plain water in case you spring a leak so you don't glycol-down the track and make it slick for everyone else?
PostPosted: Fri Apr 01, 2011 1:40 pm
NHRA rules dictate plain water. That said I have never heard of a track, running a "local" meet, checking a street driver. I have had my race car checked, however.
PostPosted: Fri Apr 01, 2011 3:19 pm
Car Model: Toad Wagon
Yeah, the glycol's a pain to clean up, and it's excellent at countering the VHT. The track crews hate it.
I run glycol cut water in my HAMBster between meets, but change it out for race day. Keeps the rust down.
Doc, do you know the manufacturer of the pump in your picture that you cut half the vanes off? I see it's blade bend direction's "cupped" favoring the direction of rotation, and would be more efficient than those bent the other way. That one'd likely not need a capture plate on the backside.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Fri Apr 01, 2011 3:31 pm
I think you can add 'water wetter' to the plain water at the track.......
PostPosted: Fri Apr 01, 2011 3:52 pm
Yep, lots of folks do that. I know several non-radiatored cars that run it.
I tried it but it still rusted up more than I like, in spite of the claims.
Race days on plain water and back to mix works for me (I re-use the mix, I'm cheap :lol: ).
Dick, 225% crazy.
PostPosted: Fri Apr 01, 2011 4:26 pm
Sorry to say that I do not know the brand of pump that is... it's just one I pulled out of the "used waterpump" box.
PostPosted: Fri Apr 01, 2011 4:52 pm
No sweat, just thought it might've helped the original poster.
Dick, 225% crazy.
PostPosted: Fri Apr 01, 2011 7:08 pm
Anti-freeze is only against the rules in Pro and S/Pro.
RT 66 checks.
Indy checks.
41 only checks your cash.
PostPosted: Fri Apr 01, 2011 9:24 pm
:lol:
I run mostly small nostalgia meets, and mostly at Famoso. They ask us to do it voluntarily, and they don't check. However if you Glycol the strip you will be invited to leave, by both the track crew and other racers. Pretty much the same at Fontana and up at Eagle Field.
Dick, 225% crazy.
PostPosted: Sat Apr 02, 2011 8:36 am
Site Admin
Thanks for the reminder! Better dump the glycol for MATS. They are rabbid about it at Las Vegas.
CJ
Users browsing this forum: Russell G and 3 guests
