It is currently Mon May 18, 2026 9:17 am
PostPosted: Sun Apr 03, 2011 7:49 am
Title says it all.
I THINK the Street Duster has SS springs, but I'd like to verify and make sure before I do some planned swapping around.
 Post subject: crooked
PostPosted: Sun Apr 03, 2011 12:31 pm
Does it set crooked? Cocked towards the passenger side? Any chance there are numbers left on the springs?
Rick
PostPosted: Mon Apr 04, 2011 6:25 pm
It doesn't really appear to sit crooked. I'll crawl up under there and look a little closer at things.
I thought there was a different leaf count or clamp arrangement on the SS springs.
PostPosted: Mon Apr 04, 2011 6:58 pm
I think the SS springs do twist the car towards the passengers side a little bit. Also the SS spring eye bolt was larger than the stock 72 swinger springs Tell me what you have Rob and I can look at Ryan's Dart. That is what he has on his car
Rick
 Post subject: S/S springs
PostPosted: Tue Apr 05, 2011 8:46 am
Numbers should be stamped(not painted on) into the spring pac near the mounting pad. Look for a 002 on one 003 on the other. that is the most common for a A-body like a Duster, 3000 lbs. 863/864 2800lbs, 456/457 3400 lbs.
PostPosted: Tue Apr 05, 2011 8:48 am
OOps, Should have said U-bolt mounting pad.
 Post subject: numbers
PostPosted: Tue Apr 05, 2011 11:08 am
That is the correct numbers, but Ryan's came in with the numbers stenciled, painted , on the springs. They may be stamped too but I'd have to check.
Rick
PostPosted: Wed Apr 06, 2011 7:09 am
Thanks for the info guys. :D
I'll get over there and crawl up under it to see what I can see.
PostPosted: Wed Apr 06, 2011 9:42 am
Sometimes I forget how many years we been doing this.Some have both paint and embossed, some just paint. Went and looked at the newest ones bought (about 2006) and they were painted. :oops:
