It is currently Sat Oct 10, 2026 2:07 pm
 Post subject: Steel head gasket prep Q
PostPosted: Tue Apr 12, 2011 7:09 am
I'm getting ready to swap out Fel-Pro head gasket for stock Chrysler steel head gasket I got from Frank to grab a little more compression. What if any treatment does that steel gasket need before it is installed?
Bill
PostPosted: Tue Apr 12, 2011 8:31 am
The most important thing needed for reliable sealing of a shim type head gasket... smooth, flat, freshly machined block and head surfaces.
PostPosted: Tue Apr 12, 2011 9:56 am
Doc,
How fresh is fresh? Had the head machined about 6000 miles or two years ago. I don't expect any goofy conditions lurking, no over heating, no hard charging, since reassembly.
Bill
PostPosted: Thu Apr 14, 2011 4:16 pm
Doc,
Bill
That looks fresh enough to me!!! How about block deck surface? Same thing? Machined 6000 miles ago with no overheating or whatsoever?
If the answer is YES, then I think you are good to go.
Take your time to CLEAN both surfaces ... and clean again before the steel gasket.
Martin
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Fri Apr 15, 2011 9:42 am
Couldn't say when top of block last visited a machine shop. I can easily brighten it up with Scotch Brite pad. The last time the head was off, the top of block was nice and clean.
PostPosted: Fri Apr 15, 2011 10:33 am
Time to get out the "long board" sanding block, pull the dowel pins and give the top of the block a nice flat sanding.
You will see every high, low, ding and dent, once you do that.
Users browsing this forum: No registered users and 18 guests
