It is currently Sat Nov 14, 2026 2:11 am
PostPosted: Thu Apr 14, 2011 11:10 am
someone have some information about the wiring of a dodge aspen 79 AT, because i need to back at the original voltage regulator box, my car have a frankestein in this part (a regulator ford with 4 pins, only in use 2) and the original is with 2 pins in a rare plug "like a triangle", a need to know how i can return to the original configuration and how can i do it.
thanks.
dodge aspen 79 AT
PostPosted: Thu Apr 14, 2011 3:02 pm
Hi, here is a good diagram (on the right) of the charging system for 1970 and newer Mopars like your '79.
PostPosted: Fri Apr 15, 2011 10:57 am
Here's the image:
PostPosted: Mon Apr 18, 2011 4:41 am
thanks, now i´ll try to discover how is the wire in the car, i must draw a diagram to compare.
dodge aspen 79 AT
