It is currently Tue Jun 16, 2026 5:51 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Wed Apr 20, 2011 11:34 am
hey anyway you can repost the photos?
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Apr 20, 2011 12:34 pm
I doubt you'll find him around here. He hasn't posted since Jan '07.
PostPosted: Wed Apr 20, 2011 1:43 pm
think there are any outhere?
slant six's RULE!
PostPosted: Wed Apr 20, 2011 2:26 pm
Doubtful. The reason he hasn't posted is that he passed away. :(
 Post subject: Yep...
PostPosted: Wed Apr 20, 2011 6:23 pm
Sadly he was a smart guy with a good future ahead of him...it was a real loss, and a shock to hear it happened.
PostPosted: Wed Apr 20, 2011 8:03 pm
sorry to hear..seems in life, good just pass'es no reason, no rhyme
be well Super6, I found your post through google search on slant six serpintine belt and here you were..
slant six's RULE!
PostPosted: Wed Apr 20, 2011 10:34 pm
The bottom pulley can be from a 3.8 Ford V6. An adapter needs to be made that will allow the pulley to conform to the damper. I used the adapter to center the pulley. A damper crank bolt is needed and the pulley needs to be drilled to match the damper.
The water pump pulley can be from a 3.0 Ford V6. A piece of flat stock can be used to align to the bottom pulley. The pulley needs to be drilled to match the water pump holes.
After this you are on your own on how to run your accessories.
PostPosted: Sat Jun 04, 2011 4:53 pm
Ok
I want to move forward on this conversion. the only accessorie I have is alt.
are these the correct items for my search...seems their on ebay.
slant six's RULE!
