It is currently Sat Jun 20, 2026 6:33 pm
PostPosted: Thu Apr 21, 2011 1:36 pm
i am blind as a bat and new to a /6, can barely see the distributor ,do you pull it and set points in, then put it back hopefully in right tooth?or 100 watt bulb and half the afternoon.
PostPosted: Thu Apr 21, 2011 1:39 pm
Hi blind or no it is a pain - best permanent relief from this pain is to go with an mopar electronic dizzy fired by an HEI module
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Apr 21, 2011 1:41 pm
Remove distributor cap. Rotate engine by hand until rotor points to a very recogniseable/repeatable position (12:00 straight up or 3:00 straight forward is what I usually use). Remove distributor, noting how rotor turns counterclockwise as you do so. Replace points and condenser on bench, reinstall distributor (start with rotor turned a little counterclockwise of whichever position you moved the engine to point the rotor to -- verify the rotor winds up back where it started before you pulled the distributor). Start engine, adjust timing.
Then save yourself the damnuisance and hassle of ever having to do this again; go to electronic ignition.
PostPosted: Thu Apr 21, 2011 1:59 pm
What Dan said - PLUS have a box of plasters ready - for some reason I always bleed when I do this
Regards,
Fanie Gerber
