It is currently Thu May 07, 2026 9:06 pm
 Post subject: Tire wheel size
PostPosted: Thu Apr 21, 2011 7:48 pm
Has anyone run 245/60/15 with a 2.76 rear?
If so, were there any issues?
Thanks.
PostPosted: Fri Apr 22, 2011 9:15 am
The 2.76 gear ratio was the only problem I had with that combo... :wink:
PostPosted: Fri Apr 22, 2011 2:57 pm
Was it too slow or a problem with braking with that combo?
PostPosted: Fri Apr 22, 2011 3:09 pm
That ratio is high... resulting in sluggish acceleration.
The vehicle did drive well on the open highway but was a "dog" around town.
PostPosted: Fri Apr 22, 2011 4:26 pm
That tire is about an inch taller than the 205/70/14 on the car now.
The extra inch would make that much of a difference?
I was planning on 225/60/15 and 245 to help fill the space at the back.
Thanks.
PostPosted: Fri Apr 22, 2011 9:09 pm
I'm running 235/60-15s all the way around on a Demon and 205/60-15s on a 4-door Dart. The Demon has stock Mopar cop car wheels, the Dart has Magnum 500s, both with stock offset. The 235s get about as close to the spring as I am comfortable. I tried a pair of 255/60s on the rear and took them off because they were up against the spring when the wheel was mounted.
There are no problems of any kind with the Dart. The 205s replaced 195/75-14s. The bigger chrome wheel seems to fill the wheel well even though the rolling diameter of the 205/60 isn't that much greater than the original tires.
You can't fix stupid. - Ron White
PostPosted: Sat Apr 23, 2011 4:44 am
Would I have any problems with fit on the back (245/60/15) on a F Body?
PostPosted: Fri Apr 29, 2011 8:01 am
Hey, 2 Darts was that with a stock motor?
PostPosted: Fri Apr 29, 2011 9:26 am
That tire is about an inch taller than the 205/70/14 on the car now. The extra inch would make that much of a difference?
Yep. Do the math. The 245/60R15 tire is 26.6" diameter. The 205/70R14 is 25.3" diameter. That's "only" 1.3" difference in diameter, but the circumference difference is 83.6" vs. 79.5". Which means your engine speed at 60 mph will be 2092 rpm with the bigger tire, 2200 rpm with the smaller tire. Both will have you running below the torque peak and make the car doggy/sluggish in stop-and-go traffic, but the effect will be exaggerated with the bigger tire. You'll be in the power valve all the time trying to get the car safely up to speed; fuel economy in town will suck. On the highway, the car will "want" to run 80+ mph with the bigger tire, 75+ with the smaller tire.
Either of these tire sizes would likely make you much happier overall with 3.23 gears.
PostPosted: Fri Apr 29, 2011 1:46 pm
Dan, thank you for your response.
The original tires were 195/75/14 at 25.5" diameter
I was thinking 215/60/15 which is 25.2 in the front
and 235/60/15 in the back (to fill the space) which is 26.1" diameter.
Would the extra .6 make that much of a difference?
Thanks.
PostPosted: Fri Apr 29, 2011 3:15 pm
What affects engine speed at any given RPM is the overall diameter of the drive wheels. Front tire size doesn't have an effect of this nature. Different-size tires front/rear is usually not a very good idea on a street-driven car.
Aannnnnd…what year and model is this?
PostPosted: Fri Apr 29, 2011 3:26 pm
79 aspen.
What bad effects does staggering have other than rotation issues?
Thanks
PostPosted: Fri Apr 29, 2011 4:33 pm
Rotational issues......longitudinal axis............swap ends
PostPosted: Sun May 01, 2011 4:37 pm
No.
PostPosted: Mon May 23, 2011 10:29 am
Thanks,
Joshua, Doc, Dan and 2 Darts for your time, responses and patience.
I finally went with 225_60_15's all round.
Thanks again.
Users browsing this forum: No registered users and 15 guests
