It is currently Tue Jun 23, 2026 10:41 am
 Post subject: 2 PCV Valves
PostPosted: Sat Apr 23, 2011 8:26 am
While putting the final touches on my super 6 set up yesterday I recalled a thread about PCV valves where SSD mentioned a plastic one that fits into the rear breather cap for early model years.
I saw that my cap had a metal elbow, pulled it and sure enough, PCV valve in the cap.
Rattled it up and down...seems ok?
So I will delete the one that someone had installed downstream.
Sure will make the hook-up to the carb port a lot cleaner.
My limited knowledge tells me performance should not have been affected by having 2 valves.
What say ye?
Super Six Conversion Stromberg
PostPosted: Sat Apr 23, 2011 9:15 am
Probably no big deal, but it's best to have just one. Clean it with spray carb cleaner.
