It is currently Tue Jun 09, 2026 9:44 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
PostPosted: Mon Apr 25, 2011 9:23 pm
I have this question under wanted tach..
http://www.slantsix.org/forum/viewtopic.php?t=44725
we have a stock 1968 dodge Dart 225, auto column shift. stock rear larger dia rear tires. mufflers 1 barrel carb all stock. I am wondering what is the best manual shift point RPMs for 1/4 mile racing? thanks!
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Apr 25, 2011 9:35 pm
Stock 225s are usually done by 4500 RPM. You'll want to try different shift points to see what's quickest. If you are willing to fiddle with the valve body and governor you can get the trans to shift by itself at the optimum RPM gaining consistency and probably bettering the ET.
PostPosted: Mon Apr 25, 2011 9:47 pm
Ok
how do I fiddle
a link possibally..?
did not know there was a governor..
slant six's RULE!
PostPosted: Mon Apr 25, 2011 10:15 pm
Sounds like you're going to need help. Start reading through the transmission section of your factory service manual to get familiar with the transmission operation. Once you've done that you should have a better idea of how to make changes to optimize transmission function for racing.
PostPosted: Tue Apr 26, 2011 5:46 am
Best shift at 4000-4500 on a stocker. I always shift manually and am very consistent (0.02-0.04 run-run) if car behaves off the line.
Adjust kickdown linkage so it is fully rearward at WOT.
PostPosted: Tue Apr 26, 2011 8:05 am
WOT ?
slant six's RULE!
PostPosted: Tue Apr 26, 2011 8:10 am
Wide Open Throttle
:mrgreen:
~RDE~
PostPosted: Thu Apr 28, 2011 6:59 am
OK
with the paperclip conected throttle cable carb linkage I only had 3/4 throttle..
I remember the seller saying how he went to a junkyard to buy a carb as the one on it was shot. well It was never propertly installed.made some test reconnections on the carb and the car launches/bangs 2nd pretty hard..I had put lighter oil 5-30 wt. but I gona re-oil back to 20-50, as on start up the oil light stays lit too long, and after a few 1/4 mile standing/rolling test runs, the motor is talking to me...181K...I would rather cruze then try and find $$$$ for a rebuild...still plan to go to 75-80 and run...them big worn tires did spin on the one side (non-sure grip)....no chirpin so the rear is light..and @ 40-50 mph /still in 2nd the ft. end was kinda floting..strange? I'm not gona shift as it rolls good now in dive.
PS.
the kick down linkage et al was all dirty/surface rust. put some never seeze ALL over....what fun.
slant six's RULE!
PostPosted: Thu Apr 28, 2011 5:36 pm
Okay, So I understand how to adjust Line pressure and The Lickdown etc.
How Does the Governor Figure into all this? I would like to learn.
Do you have to remove the tailshaft to tune the Governor i.e. Putting weights or shims in the Governor itself or is it done in the valve body somewhere?
Thanks!
PostPosted: Thu Apr 28, 2011 6:17 pm
Not to thread jack but what is redline on a bone stock 225? i have my tach set at 4k as redline.
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Fri Apr 29, 2011 4:51 am
When the valves float!
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Apr 29, 2011 9:13 am
Errr... for me, the stock 1 bbl carb runs-out of CFM before the valves float. :roll: :lol: :wink:
PostPosted: Fri Apr 29, 2011 10:33 am
Yep, I have the same problem... It's the restriction in the system.
PostPosted: Fri Apr 29, 2011 12:41 pm
The valve body is an analog hydraulic computer. This is why shift kits are sometimes called reprogramming kits. For the transmission to shift a shift valve has to move. Governor pressure acts on one end of the shift valve while there is a spring and throttle pressure on the other end of the valve. Governor pressure has to overcome the shift valve spring pressure and throttle pressure to move the shift valve. Raising the throttle pressure or lowering the governor pressure will raise both the 1-2 and 2-3 shift points. If one shift point is off then you need to play with the spring on the appropriate shift valve.
There are different weights available for the governor. Yes, the tail shaft has to be removed to service the governor.
Thanks!
You're welcome. I hope this makes sense!
PostPosted: Fri Apr 29, 2011 10:15 pm
haha well that doesnt help me much. lol i see 4000-4500 above. so would 4500 be redline? i have a manual tranny and low gears, when i get to 4k its screamin pretty good. Never gone past 4k but if i can go to 4500, would you think itd make a difference in 0-60 time?
