It is currently Wed Jun 17, 2026 3:09 am
PostPosted: Tue Apr 26, 2011 9:21 am
doing a swap on a 67 gt with a 225 727 auto trans - to a 170 2 barrel using the same 727 trans. What do I need to have for the linkage to hook up correctly? What size and make carb will work best?
PostPosted: Tue Apr 26, 2011 9:44 am
If you really have a 727 auto trans in that 67 Dart and you have a 67 and older 170 SL6 engine, then you have a parts combination that will not go together.
(all 727s have a "big hub" converter nose and all 60 thru 67 170 Slants have a small pilot in the back of the crankshaft)
If the Dart really has a 66-67 904 AT, then it will all go together with an oil pan / pick-up tube swap. (if the 170 is 60-66)
You may need to adjust the exhaust pipe because it will hang lower when installed onto the "shorter" 170.
You will need factory Super-Six linkage or a Locker cable kit... and some fab time, in order to get the throttle pressure working.
PostPosted: Tue Apr 26, 2011 10:33 am
Is there a way to hook up the manual trans and still keep my gt center console?
PostPosted: Tue Apr 26, 2011 11:55 am
You'd probably have to sell it and buy a stick shift console....but thats just one of 50 different things you'd have to do to make it a manual.
Try and find a 904....they're dirt cheap.
