It is currently Sun Jun 14, 2026 11:05 am
Post new topic  Reply to topic  [ 80 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Sat Feb 26, 2011 7:09 pm
Change of plans. I found a cast aluminum carb hat from a GM Turbo. 5-1/4" OD, 2-1/2" inlet. Inlet is 3 to 5-1/2" above top of carb. I'm thinking it's about as good as good gets for 75.00.
1960 Seneca 225 turbo soon to be EFI
PostPosted: Thu Mar 03, 2011 5:49 pm
Painted engine with DuPont Centari. Color VW/Audi L96Y. I think its too blue but it looks good.
PostPosted: Wed Mar 30, 2011 7:53 am
Hello ken,
I am the guy who mailed you from France yesterday.
You made a very nice job on a very nice car.
Rustoleum is a very good product, I used it to stop the rust on floor pans and frames on French cars, a Citroen 2 cv, a Citroen DS, and a Peugeot 403.
I will follow your topic to get information for the restoration of my car which is the same as yours. They are very rare in France and, thanks to the informaton on the forum, I hope i manage it.
 Post subject: under hood wiring
PostPosted: Tue Apr 26, 2011 5:07 pm
I picked up a fuse/relay box from a late model Crown Vic. My car came with no fuses. So far the wiring is shaping up pretty well.
Relay for fuel pump, HEI and horns with one space left.
I mounted it on the radiator support on the passenger side. Coil and module just below it. The master boost control and voltage regulator on the fender immediately adjacent.
While I was at it I nabbed the windshield solvent tank and pump. Its a nice fit at the top of the fender. Just behind that I mounted the starter solenoid.
PostPosted: Tue Apr 26, 2011 5:13 pm
After installing the tranny I decided to look into straightening out the clutch linkage. I found a part number for z bar bushings and went to a dodge dealer to check it out. The part is the same all the way through the early 1980's slant six pick up trucks. Be advised they come packaged 1/2 of one bushing per unit package- which means 4 half bushings are required. Spring clips, too. They are still stocked at dealers.
PostPosted: Tue Apr 26, 2011 5:51 pm
The paint I used on the Dodge is Nason 1 step acrylic enamel w/ hardener. Good (not great) paint. Due to EPA rules on solvent content, the can recommends a fairly thick mix. This led to quite a bit of gassing (leaving bubble like imperfections). Next time around I will reduce half again as much and expect much better results.
I tried thinning Rustoleum with lacquer thinner but the gassing was similar, so I tried again w/ mineral spirits and the difference was night and day.
Note : bug legs are a lot easier to wet sand out than bubbles or runs!
Yes for the ratio is NORMALLY 2:1:.5..... in other words 2 parts paint, 1 part reducer, .5 hardener. (ie: 8oz paint, 4 oz reducer, 1 oz of hardener) and I know, I know, states having the regs they have makes it tough, but its not like you are in business drawing customers and attention to yourself, so I would just reduce it to the specs listed if you are using a quality paint gun. Just be sure to wear a quality respirator. Last car I painted was a base coat clear coat affair, and not knowing the ins and outs of 2 part system vs. the single stage was an eye opener, but job came out ok. Where oh where has the good ole paint gone? :roll:
MRO....
 Post subject: Ford Fuse box install
PostPosted: Sat Apr 30, 2011 12:29 pm
I opted for the Ford box because I liked the size and mounting. I admit I didn't look at all that many options. I have more straightening up to do as well as relocating the battery to the trunk.
PostPosted: Sun May 15, 2011 5:37 am
I'm making some progress. Intake/exhaust/carb installed. Throttle linkage just needs return springs.
Next is fuel pump and regulator and its break-in time. :lol:
Then I can install turbo and start playing around.
PostPosted: Sun May 15, 2011 8:41 am
Ken, I cant wait to see your project all done!
Keep on it.
Also the Turbo EFI Hat on A carb is too funny!:D
PostPosted: Mon May 23, 2011 7:38 pm
I broke in the engine with comp break in oil. I took it out and shook out some minor bugs. The tranny is smooth as silk. I still haven't wired the overdrive unit though.
The disc brake kit was worth every penny.
The 500 CFM Holley may be a bit much, but so far it idles. accelerates and cruises fine. I'll be checking mpg. 1 bbl with standard trans gave me 19 mpg before engine rebuild.
A week or so of daily driving and I'll start the turbo install.
:lol:
PostPosted: Tue May 24, 2011 1:41 pm
Site Admin
What are you using for the overdrive?
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Wed May 25, 2011 2:57 am
Borg Warner R10J I think the trans is a T85. Modified the bell housing and flywheel and used a 10" clutch disc from a '63 Dodge pick-up.
PostPosted: Wed May 25, 2011 8:14 pm
Battery relo went ok. Still plenty of room in the trunk.
PostPosted: Wed May 25, 2011 8:22 pm
A fresh slant is a dream to drive!!!
80 mile commute, no problems. 8)
PostPosted: Wed May 25, 2011 8:45 pm
That's a nice looking battery box. What did you have to give for it?
