It is currently Fri Dec 26, 2025 6:27 am
PostPosted: Fri Aug 29, 2003 4:18 pm
I am planning on replacing my exhaust manifold this weekend. On the two outboard bolts that hold the manifolds together, is it OK to use grade 5 bolts, or should I use grade 8? Also, should I use lock washers under the heads and under the inboard nut?
PostPosted: Fri Aug 29, 2003 4:29 pm
The factory used low grade bolts here with flat washers under the heads.
PostPosted: Fri Aug 29, 2003 4:35 pm
Than I'll be fine. Thanks Doug. 8)
PostPosted: Fri Aug 29, 2003 5:05 pm
To maintain your future sanity, you could upgrade to stainless steel bolts..Dave
Troops on the battlefield have a far better view of the battle then the generals who lead them
PostPosted: Fri Aug 29, 2003 5:13 pm
One word... antiseize.
PostPosted: Fri Aug 29, 2003 6:57 pm
Stainless steel expands more than cast iron.
Joug
Sorry, my english is not very good
PostPosted: Fri Aug 29, 2003 10:50 pm
Taken care of! 8)
Users browsing this forum: Bing [Bot], Killer6 and 8 guests
