It is currently Fri Jun 19, 2026 5:56 am
 Post subject: 0.080 piston rings
PostPosted: Wed Apr 27, 2011 5:04 pm
has anybody got a contact that i can buy a set of stock (not metric) 80 over cast piston ring or cross reference rings i can use?
 Post subject: Lol...
PostPosted: Wed Apr 27, 2011 7:58 pm
You know I thought it was funny that Rock Auto has .080 over pistons in the menu...but the OS rings only go up to .060...
Good question to ask....
PostPosted: Wed Apr 27, 2011 8:20 pm
You may be able to determine a part number for the .080 from the .060, then look for the .080 rings.........
PostPosted: Wed Apr 27, 2011 9:40 pm
The only engine I have found that runs that size bore is some of the Harley Davidson bikes. I have no idea what ring package they run though.
I am guessing you all ready have your pistons. If not I would go a different route.
Jess
PostPosted: Wed Apr 27, 2011 9:51 pm
Standard size is 3.40
2 compression rings of 5/64
1 oil ring of 3/16
Oversizes would be 3.42 3.43 3.44 and 3.46
You need to find a piston that uses 2 5/64 rings and 1 3/16 that comes standard at 3.48 bore or can get there with oversizes......
PostPosted: Wed Apr 27, 2011 10:01 pm
I just confirmed that the Harley Davidson piston are the same ring thickness as the slant six. Its one of the older HD's that have the 3.480 bore as a over bore ( I think it was the pan or KNuckle).
This shoudl get you a set if you look close at the specs.
BTW I bet some of the Ozzy guys can come up with a set also.
Jess
PostPosted: Wed Apr 27, 2011 10:06 pm
I just e-mailed Hastings to see if they make the 687 in +.080".
PostPosted: Wed Apr 27, 2011 10:21 pm
GM had a 4 cyl (140cuin) at 3.50 73-77
GM 8 cyl at 3.50 (267cuin) 79-81
Olds 8 cyl at 3.50 (260cuin) 79-81
with the 5/64 and 3/16 rings.
You could probably file fit these if you had to.
PostPosted: Wed Apr 27, 2011 10:35 pm
The Harley pistons are listed as 3 7/16 = 3.4375
some listings say 3.438
Then lots of oversizes .010 - .070 (.010 step)
I'd use .050 and file fit.
Note: I haven't found the ring thicknesses for the HD rings....
PostPosted: Wed Apr 27, 2011 10:41 pm
Doesn't look like the Harley rings are the correct thickness:
http://www.hastingsmfg.com/RingFinderMa ... Y-DAVIDSON
PostPosted: Thu Apr 28, 2011 5:16 am
these piston are in the blower motor, i was looking for a spare set if i cook the rings, it has happened before.did the older 2.2 dodges have a 0.040 over piston that used a standard ring not metric? i have e-mailed hastings to, no answer yet. the GM vega had a 141cid 4cyl with a 3.50" bore will these file to fit if i can find them? are the 267cid a 3.50" bore to? i haven`t checked these. all the supplier have the piston but no rings. rock auto have drop the piston so i don`t know what that means!
PostPosted: Thu Apr 28, 2011 5:50 am
i have found 2 sets on e-bay , standard 4.4l gm truck but the decripition saids 5/16", i think that`s a miss print!
PostPosted: Thu Apr 28, 2011 8:15 am
i just got an e-mail from hasting`s,Terry~
We do still have the set in our line...a 3.4800" bore with a 5/64, 5/64, 3/16 ring groove layout. You can order directly from Hasitngs on a credit card by calling 1-800-776-1088 #2. The set you would order is a 687080 for a plain cast iron top ring - $57.46 + shipping, 2c687080 for chrome top groove ring - $79.35 + shipping or 2m687080 for a moly top ring - $67.24 + shipping.
If you have other questions or need further assistance, feel free to contact me again directly anytime.
Best Regards,
Lisa
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 1 guest
