It is currently Fri Jul 10, 2026 1:58 am
PostPosted: Sat Apr 30, 2011 2:21 pm
gasoline 225 power tug..is the motor anything special? trans? rear?
I see them 4sale now and then ..just wondering if anyone has had one and what have they done with it?
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Apr 30, 2011 5:05 pm
Its a industrial 225 engine-nothing usable for street use.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Sat Apr 30, 2011 5:08 pm
If it is propane powered it might be worth grabbing the carb and propane equipment off of it.
PostPosted: Sat Apr 30, 2011 5:49 pm
well some are gasoline is the trans anything? or rear? anyone know what /how/where they were built?
history on these strange units...
found this 727 trans..
http://www.projectaircraft.com/northwestern_tug.htm
slant six's RULE!
PostPosted: Sat Apr 30, 2011 6:07 pm
The engine 'might' have a different cam than automotive, but the block and head should be the same as automotive. the crank and rods may be shot peinned but are otherwise the same.
Dave
1972 d-100 parts truck
 Post subject: Here you go
PostPosted: Sun May 01, 2011 5:18 am
Look Here. http://slantsix.org/forum/viewtopic.php?t=44316
I have the engine and tranny but have not had time to get them apart. Mine was a 727 transmission with flanged output. Rear end was facing backward and had some kind on gear reduction drive on it. They are Heavy!
Rick
PostPosted: Sun May 01, 2011 9:32 am
what manfacture was the rear? sure grip? disks/drums..any info would be good.
slant six's RULE!
PostPosted: Sun May 01, 2011 10:13 am
These rear axles are too narrow and too heavy for a car. You could build a really narrow 1 ton truck with one though.
 Post subject: Re: Here you go
PostPosted: Sun May 01, 2011 11:03 am
Rick
did you ever get ur's running? or check the rear ratio, the low gearing may have been in that gear reduction part.
slant six's RULE!
 Post subject: Rear
PostPosted: Sun May 01, 2011 12:30 pm
I did not buy it to get it running. I only bought it to part it out and keep the parts I wanted. I'm hoping it has shot peened rods...etc. but won't know till later in the summer. Mine was built in 1980, It had some sort of heavy duty rear that would not have been acceptable for anything on a car. It was drum brakes and I am guessing the shoes were maybe 3 1/2-4" wide and maybe 12" diameter.
I realy lam not sure on this point, but I think the rear end was a split housing bolted together side to side with the rear pointing backwards. The gear reduction was bolted directly to the rear and had a yoke pointing to the front over top of the rear. The transmission was connected to the rear by a short drive line with a slip yoke on it. 727 output was shorter than normal and had a tailshaft mounted brake drum for the emergency brake.
Hope that helps,
Rick
PostPosted: Sun May 01, 2011 4:29 pm
Nope. Same.
PostPosted: Sun May 01, 2011 4:31 pm
Nope, that's the 225-2 and 225-3 truck engines you're thinking of.
PostPosted: Sun May 01, 2011 5:11 pm
how can u tell if their shot peen'd
slant six's RULE!
PostPosted: Mon May 02, 2011 5:36 pm
Car Model: 64 Valiant
If its freshly done, its fairly easy to tell. Sometimes some of the real fine shot is still trapped between the head of the rod bolts and the beam of the rod, even from the factory. If it has a bazillion hours on it, you are just taking someones word it has been done. Its sorta like a freshly sandblasted finish when it is first done, but after its been exposed to oil grime and sludge for a while its not as obvious to see it.
PostPosted: Mon May 02, 2011 6:00 pm
There's really no reason to go hunting high and low for shot-peened crank and rods. If you want shot-peened crank and rods…take your crank and your rods and go get them shot-peened. It's neither slow nor difficult nor costly.
