It is currently Wed Jun 17, 2026 2:06 am
 Post subject: crank dampner help!
PostPosted: Mon May 02, 2011 8:51 pm
Here's my dilemma I was trying to remove my crank dampner with a two jaw puller and I pulled the pulley off the dampner
Is there a way to press the pulley back on or should I try and replace the dampner with a new one?
also there is a rubber ring between the dampner and the pulley I think that would need to be replaced as will does anybody have any ideas were I can get a new one?
Does anybody make a after market dampner?
The motor is a 69 motor
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Mon May 02, 2011 9:00 pm
Do a search on this site. I know there are several companies that can recondition the one you have or sell you a new one. As far as I know it is not something you can do in your garage.
Super Six Conversion Stromberg
PostPosted: Mon May 02, 2011 9:19 pm
I did do a search before I posted and I couldn't find any info
Thanks Aaron
Maybe Charlie or slantsixdan will chime in
Thanks .org for all your help!!!!!!!!!
PostPosted: Mon May 02, 2011 9:26 pm
Here and Here
 Post subject: Re: crank dampner help!
PostPosted: Mon May 02, 2011 9:55 pm
Bummer. Next time use the threaded holes in the damper hub.
You can't just press it back together, but it can be rebuilt. I like the Powerbond new ones myself.
PostPosted: Mon May 02, 2011 10:48 pm
Tell me about Joshua I'm close to getting this motor back together and I wanted to install the double roller time chain I got
Do u no who carries the powerbond models?
Thanks
Aaron
PostPosted: Tue May 03, 2011 12:51 am
Here you go.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 2 guests
