It is currently Sun Nov 22, 2026 6:21 pm
 Post subject: broken t-case...weird?
PostPosted: Tue May 03, 2011 9:47 am
so i decided to try my 4x4 again after it failed on my this winter ...in a snowbank.what was happening was whenever i put it in 4 wheel low or high'' it would get stuck and not move.so i tried it again yesterday ..same thing. so i pulled the inspection plate for the front wheel drive gear ,whata ya know the chains chewed to peices.never had this ,especialy with these old t cases its a 1976 np 203 i beleive.its in my 4x4 conversion van with a 727 and slant 6.WHAT CAUSED THIS ???? i have a replacement already but thought it was weir?
jimbo
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Tue May 03, 2011 2:36 pm
Thats is very common for the NP203. The chain wads up and takes out all the monkey motion.
They are a full time TC with a "differential" between shafts.
If you can.... replace it with a NP 208....lose 100 lbs....gain the ability to run 2wd.
NP 203 is my least favourite TC..........
