It is currently Sun May 10, 2026 2:32 am
 Post subject: traction...?
PostPosted: Tue May 03, 2011 3:05 pm
ALL stock 1968 Dodge Dart slant
I put some worn big tires on the rear..have high air pressure in tire ..
I can brake and spin the one tire...obviously the ft. brakes are much better then the rear....
going up hill in ft. of our home.
any thoughts for the track?
[img][img]http://img534.imageshack.us/img534/9169/trackrat001.jpg[/img]
Uploaded with ImageShack.us[/img]
[img][img]http://img34.imageshack.us/img34/7070/trackrat002.jpg[/img]
[img][img]http://img709.imageshack.us/img709/4147/trackrat004.jpg[/img]
slant six's RULE!
http://www.usajon.com
PostPosted: Tue May 03, 2011 3:13 pm
It looks like the air pressure is a little high. The rear end may be too high in the air which will transfer weight to the front. Lower the back if you can. Also, those MTs should get sticky if you get them hot so a burnout will help at the track. Sure-Grip will help more. Hot Lap or other tire treatment can also help.
PostPosted: Tue May 03, 2011 3:49 pm
well, I don't think it is too high see photo
[img][img]http://img718.imageshack.us/img718/1186/trackrat005.jpg[/img]
the Dart is stock so If Im correct it has a 7.25 rear, are there any Sure-Grips out there w/gears ...until I mod the motor/trans I feel that small rear can hold up..any thoughts?
I saw an article on abodiesonly about a 1973 Dodge Dart w/ an explorer ? 8.8 rear in a SB V8 11.02 1/4 mile car.
being on a buget they look cheaper then an 8 3/4/Dana 60
anyone know low bucks rears that will work now and later with some build up on motor..et al.[/img]
slant six's RULE!
PostPosted: Wed May 04, 2011 12:42 am
Site Admin
There were sure grips for the 7.25"
Dump some of the air out of the right rear tire. That helps a one-legger hook. If your running road pressure, dump passenger side tire pressure down around 18-22# Leave the other one alone. You'll have to play with it to get it right. VHT at the track will help with the launch.
Don't know about the 8.8 Ford. I run an 8" Ford out of a '72-ish Maverick. Be careful with info from FABO. It's like reading the National Inquirer. :lol:
The camera angle on your photo from the rear makes it look pretty high.
2¢
CJ
PostPosted: Wed May 04, 2011 6:49 am
I have an Explorer 8.8 in my Valaint. Its not a boltin swap. It is however an excellent choice.
PostPosted: Wed May 04, 2011 9:39 am
why not a bolt in?
slant six's RULE!
PostPosted: Wed May 04, 2011 10:49 am
Housing has to be narrowed for one. Read all about Sandy's 8.8 adventures.
PostPosted: Wed May 04, 2011 11:18 am
yes.
here's an neat list I found
seems our 1968 Dsrt is 56.5 inches between backing plates...
scrol down
http://www.chevytrucks.org/tech/ifs&rearend.htm
slant six's RULE!
PostPosted: Sat Jul 02, 2011 3:43 pm
2¢
CJ
lol cj... you know that goes both ways...
nut why not find a 8.25? you can get a complete setup for like 200 bucks from the junk yard
be careful as the 2.20 and 2.45 cases cant have better ratio's installed in them
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
