It is currently Mon Nov 23, 2026 5:39 am
 Post subject: 904 neutral grinding
PostPosted: Wed May 04, 2011 8:46 pm
Ok, I ran a search and couldn't find this question. When I go from reverse to neutral or drive to neutral, it grinds either until I shift out sometimes but most of the time it's only for a second or two. Please help! 904 column shift
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Thu May 05, 2011 8:15 am
The only thing I can think of that would grind inside the trans would be the park pawl. Are you moving when you shift or completely stopped?
~RDE~
PostPosted: Thu May 05, 2011 3:11 pm
If it's grinding shifting into neutral you have a clutch pack/bushing eating itself. Pull the pan and see what's laying in it. :?
PostPosted: Thu May 05, 2011 8:51 pm
Alright will do, also going from reverse to park causes this too
PostPosted: Thu May 12, 2011 9:15 pm
I think I figured this out, the starter isn't disengaging all the way sometimes so it grinds when i change from reverse/drive to neutral
