It is currently Thu Jun 04, 2026 2:46 pm
PostPosted: Fri May 06, 2011 7:14 pm
Hey guys
Soo I did the hei ignition conversion. After a few dumb mistakes(not grounding the module and forgetting the curb idle screw was all the way in to prevent it from dieing, that's another story). Anyways she purrrs like a kitten.... To an extent. After long periods of idle, maybe a couple minutes she'll start to kinda surge I tap the throttle past 1k and she's fine. Didn't replace my carb cuz it had a ported spark tube and I've been lookin for a super six. Is it just the carb? I'll post some pics of my ignition setup when I get the pictures on my computer. Runs much better, feel a difference in power and starts so much easier. Just the little idle problem is all.
Any suggestions?
Thanks
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Fri May 06, 2011 9:01 pm
Check for vacuum leaks and possibly the HEI module being mounted in a place where it gets too hot.
PostPosted: Fri May 06, 2011 9:51 pm
It's probably a vaccum leak then. I have a picture of my setup on the hei disscussion thread. The heat sink is out of a computer and is overkill but hey it works. I'll look at it tomorrow. I'll be putting the 1" carb spacer in (my dad had it laying in his garage). I'm just happy I did the conversion and it actually works. Lol
PostPosted: Fri May 06, 2011 9:56 pm
Oh also reed the one plug I pulled out had kind of a rust color to it, it rubbed of, kinda powdery. I know it's running rich again. Is that just from being rich?
PostPosted: Fri May 06, 2011 11:37 pm
Rust color might just be gasoline additives. Normal color is a light tan.
PostPosted: Sat May 07, 2011 7:48 am
I did use an octane booster a couple fillups. It definatley improved performance.
PostPosted: Sat May 07, 2011 8:35 am
Octane booster does not improve performance.
PostPosted: Sat May 07, 2011 9:13 am
Sorry A little more oomph. according to the seat of my pants.
PostPosted: Sat May 07, 2011 2:51 pm
Still no. The octane boost is only to raise the octane of the gas and cut down on spark knock/preignition.
Cheers, Wizard
PostPosted: Sat May 07, 2011 6:15 pm
Sorry Ross.../Dan and Wizard is right. Higher octane helps stop knock, so spending all that extra money on 93 octane is a waste of money unless needed. With a high compression motor, 12 or 13 to 1, or higher, pump gas sometimes needs extra octane to run properly. Ethel is no longer available so we add octane boost to help keep the motor running smooth.
A little rebellion now and then... is a medicine necessary for the sound health of government. Thomas Jefferson
PostPosted: Sun May 08, 2011 12:14 am
I just bought an octane booster. Which was like $4. There's no way in hell I'd fill up on premium. $3.85 for regular is bad enough! Quick question, could a dirty fuel filter cause the surging? I replaced it in January. But I've filled up quite a few times since then, the previous owner didn't use it much, I'm wondering if filling up so much has washed gunk out of the tank and into the filter?!
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
