It is currently Mon Nov 23, 2026 12:48 am
 Post subject: rearend from SBP to BBP
PostPosted: Sat May 07, 2011 9:15 am
I have a 63 Valiant convt. with a 7 1/4 SBP. I want a BBP rearend. What is the easiest/fastest way to go. I was told mine is a narrow body a-body. Does this mean a later model a body will not fit due to width differances? Thanks for your input.
A little rebellion now and then... is a medicine necessary for the sound health of government. Thomas Jefferson
PostPosted: Sat May 07, 2011 2:54 pm
Easiest way is to find a 7-1/4 or 8-1/4 from a '73 and later disc brake A body. The "narrow body" rears are the same width as the later A's.
PostPosted: Sun May 08, 2011 12:15 pm
Alternative: You might look into early V8 Mustang and V8 Maverick rear ends. They use a 5-on-4.5" bolt pattern, although I think the center register is different. The width and spring perches are pretty close, and they may not even require a new or modified driveshaft, unlike the 8-1/4" and 8-3/4" Mopar units.
On any rear end, check the gear ratio. Some of the 70's cars had really tall gearing. My son's Monarch came with 2.47:1. :cry:
PostPosted: Sun May 08, 2011 12:21 pm
just picked up a 833OD. Need to rebuild it, but after that Iwould need to do drive shaft work anyway. Thanks to ya'll input. Love this board.
