It is currently Sat May 09, 2026 1:43 pm
 Post subject: Rear 9" drum locking
PostPosted: Tue May 10, 2011 6:07 am
This is on my 64 barracuda with 9" drum brakes. When I bought the car the guy told me he had a problem with the left rear drum brake adjusting tight to the point where the brake would be applied until he reversed to get it undone. Well I pulled the rear drum and found missing hardware for the self adjuster. Someone must have removed hardware to keep the problem from happening. I installed all new hardware (springs, adjuster, shoes, cables) on both sides and adjusted the brakes and everything was good. Yesterday in the local parkinglot I could tell the back left brake had gotten tight so I had to reverse to free it up. Made 1 more stop before home and same thing was happening. What will cause the left rear self adjuster to slowly tighten up the brake? Shoes were put on correctly (according to sevice manual) same with all hardware. Any ideas?
64 barracuda
64 valiant convertable
65 valiant sedan
65 signet
74 vw beetle convertable
79 E-250 4WD van
94 dodge dakota
PostPosted: Tue May 10, 2011 7:19 am
I wonder if it has something to do with the parking brake cables?
PostPosted: Tue May 10, 2011 8:55 am
The '68-and-earlier self adjusters are a damnuisance. The '69-up ones work much more reliably and generally without random problems like this. The later self-adjustors can be installed on the earlier cars as long as you get the whole setup, all the pieces, and don't try to mix and match. Watch out for low-quality garbage from China; inspect the parts carefully.
PostPosted: Tue May 10, 2011 9:02 am
What's the difference between the 68 and the 69 that makes them so different?
64 barracuda
65 valiant sedan
65 signet
79 E-250 4WD van
94 dodge dakota
PostPosted: Tue May 10, 2011 9:04 am
Cables were way too tight when I bought the car but after getting them adjusted they shouldn't be the cause of this problem.
64 barracuda
65 valiant sedan
65 signet
79 E-250 4WD van
94 dodge dakota
PostPosted: Tue May 10, 2011 9:42 am
Rusted parking brake cables can "ratchet" on just by applying the brakes, and eventually they cause lockup.
This happened on my first date (March 16, 1990) with my wife Christine! After dinner, we went to go for a drive and the car wouldn't move ('68 Dart, still have it). I knew we would spend the rest of our lives together when she crawled under the car with me and asked to see what I was doing and held the flashlight. We were 18, been together 21 years now... I cut the p-brake cables the next day with a hacksaw and that fixed it.
I would disconnect that one cable at the brake shoe and see if it stops. If not the cable(s), then remove all self adjuster stuff and just manually adjust them every 10k or so. 69-up hardware would be the orthodox way to fix it.
PostPosted: Tue May 10, 2011 9:46 am
Up to 69, the adjuster "lever" hooks onto the shoe and uses a stiff spring and cable, to pull the lever up, upon rearward braking, then the spring force pulls the lever back down, advancing the star wheel from the top.
The 69 and later system is opposite, the lever mounts to a small pin, pressed into the brake shoe and the lever sits below the star wheel. Upon rear braking, that cable pulls the lever up, advancing the star wheel and a small spring returns it to "rest". This system has the "positive action" and harder "pull force" of the cable, instead of depending on a spring's force, to advance the star wheel.
As for your locking situation, look closely at the PB cables to be sure they are not sticking... look to be sure both shoes return and rest solidly on the main anchor pin.
PostPosted: Tue May 10, 2011 11:31 am
Would the parking brake ratchet even though the parking brakes is not being used?
64 barracuda
65 valiant sedan
65 signet
79 E-250 4WD van
94 dodge dakota
PostPosted: Tue May 10, 2011 1:14 pm
Absolutely. I never used the PB in my '68 Dart before that, and still don't.
PostPosted: Tue May 10, 2011 1:55 pm
OK thanks I'm going to check out the parking brake cable and post what I find. Hoping to take it to Mason Dixon.
64 barracuda
65 valiant sedan
65 signet
79 E-250 4WD van
94 dodge dakota
PostPosted: Tue May 10, 2011 4:35 pm
Took apart left rear drum and found parking brake cable didn't want to move very much. Removed cable and proceeded to spray down and oil up until it slid a bit better. Reinstalled and readjusted the brakes. Looks like a temp fix for now. Do not want to remove "emergency" brake until it's converted over to dual reservoir master cyl. Looks like I know what I'm doing this weekend. Thanks for all the advice.
64 barracuda
65 valiant sedan
65 signet
79 E-250 4WD van
94 dodge dakota
PostPosted: Wed May 11, 2011 5:55 am
Cool. Let us know what you find.
PostPosted: Wed May 11, 2011 6:52 am
This brings back memories. Back in the sixties Maine required six month vehicle safety inspections. Due to winter road salt, most cars just rotted away in six years, my Dart was no exception. I recall fighting with stuck corroded emergency brake cables every six months to get them to work so to pass inspection.
The other bugger-boo was stuck eccentric cams used to adjust front end alignment. I would start with penetrating oil & long wrench extensions about a week before arriving at the front end alignment shop to make sure they could make the adjustments.
Yup… they sure don’t make’em like they used to, and that works for me.
