It is currently Sat May 09, 2026 2:25 pm
 Post subject: stall-converter
PostPosted: Sun Aug 31, 2003 4:06 pm
Does anyone make a stall converter to fit the slant bell-housing? If so let me know or what alternatives do we have for a more radical cam. Let me know.
Jared
1974 Dart Sport
PostPosted: Sun Aug 31, 2003 6:26 pm
Just call a converter manufacturer and tell them what you want to do. They will take care of you. I personally use Midwest in Rockford, IL. 815/229-9808, but there are many good ones out there. :shock:
PostPosted: Mon Sep 29, 2003 12:46 pm
I take it this means a convertor won't swap between a small block 904/flexplate to a SL6 904/flexplate?
I was just about to post asking that, but decided to scroll through first and see if anyone else had said anything relevant to topic.
"When applied at precisely the right time, Ignorance is a powerful tool, usually even surpassing knowledge" E.J. "Michigan Madman" Potter.
PostPosted: Mon Sep 29, 2003 2:54 pm
Yes, you can use a smallblock TC on a Slant flexplate and vice versa. Just make sure the register pin is right for your year motor (crank hub hole). '68-up Slants had same size as SBs, but earlier ones had a smaller pin. Also, 360 externally balanced engines may have weights on the TC and should probably not be used with an internally balanced Slant (all were).
