It is currently Fri Jul 17, 2026 9:14 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Wed May 11, 2011 2:47 pm
If I do get time to run a return line, could I run it from my existing holley 12-803 regulator, or will I need a bypass type regulator?
Ryan Covalt
PostPosted: Wed May 11, 2011 3:23 pm
I would not try to run a return line from a dead-dead type regulator. All you can do is bleed off a little pressure, but that leaves you with less fuel for the engine. Dead head regulators cannot cut off the return line like a bypass regulator.
If you PM me your e-mail address I can send you a chart that will help you select the right fuel jet. NOS uses the same fuel solenoid for EFI as carb so you shouldn't have a problem just dropping in a smaller fuel jet. It should be about a .032" jet for 100hp shot with 45 psi fuel pressure. .026" for 75hp and .022 for 50hp.
If I remember correctly you went overkill on your fuel pump. So long as you have adequate fuel volume and pressure for the total HP produced
PostPosted: Sat May 14, 2011 10:12 pm
I went a head and ordered a set of nitrous fuel jets for 45lbs of fuel pressure. This should be the simplest solution for the race this saturday. Thanks for the help. Hopefully it works and I can put down some faster times this year!
Ryan Covalt
