It is currently Tue Jun 23, 2026 8:52 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sun May 15, 2011 11:35 am
Yeah. That's it! I'll convert the AFB from a 500 to a 600 and take it for a spin. That should help. :D
Thanks 'Zilla! I'm getting tunnel vision on this thing.
I think your right Lou. I advanced the cam to get it to 102-103ish°
I have a bigger bushing.
Today I'm going out to pull some un-needed weight out of the car. Stuff like the Mopar ignition parts, and so forth. Transfering the OEM ignition to Linda's '63 GT.
I may put a bit of weight back into the rear of the car.
Lots of fun! :lol:
Too wet to fire the forge up. With all the shavings and aluminum scrap I've been building up, I need to make a pour pretty soon. I've got some ideas for a trinket or two.
PostPosted: Sun May 15, 2011 12:13 pm
If it's falling down over 5K, look at too much timing, valve springs, or too little fuel volume. Even with a crap AFB on it it should wind 6500 easy. :shock:
PostPosted: Sun May 15, 2011 12:44 pm
Holley Red pump, 3/8" all the way to the bowls. Probably not fuel.
All in, maybe 28° advance. Drop that to 26°. Keep the 14° base.
Could go back on the Holley 600. Shoot somewhere in the middle for jetting. Just too many elevation changes to make that fun with our circuit. It ranges from five feet to perhaps 2500'. Not that bad, but the Holley tends to need a nurse maid as altitude and temperature change. Not as bad as it would be with a Hyperpak manifold. I'll stick with the short runner Offy.
I'll try it with the AFB converted back to 600 cfm so I don't have to baby-sit the Holley.
Got some weight out of the front end. Still looking for my old set of shocks. They need the oil dumped out of them still. Been saving them for that for a couple of years. Just don't know where I put them now. :roll:
The story of my shop.
Knocked an engine stand over today, came within a couple inches of hitting the Alfa. I either need to sell that car, or stop fooling with slant sixes and get back to sporty cars. I about had a coronary. :shock:
PostPosted: Wed May 18, 2011 6:25 pm
this is interesting! mine lays down @ like 5500 with a 246@ .050 cam... maybe i do have to much timing (lockout @ 32)
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Wed May 18, 2011 6:26 pm
slant or imports? i know the feeling i have a 240z sitting out back! but about the timing im running 32 total all the time lol... no ping but have 10:1 comp
PostPosted: Wed May 18, 2011 7:46 pm
Lots of things will make a 225 not rev high. 32 deg is too much, yep. 30 max, and more like 26-28 is my experience. Restrictive exhaust or induction, or mixture at high RPM and load, or....
