It is currently Fri Jul 17, 2026 7:47 pm
 Post subject: Front shocks
PostPosted: Tue May 17, 2011 5:16 pm
Greg,
I have new 90/10 shocks on my Valiant if you want to try them? Just let me know and I can pull them off and bring them to the track.
Rick
PostPosted: Tue May 17, 2011 8:21 pm
Do you have a manual valve body in the trans?
Yep I do have a Manual Valve body
If so put it in 3rd gear and stall it, That will tell you what your real stall is.
I will try That.
Do you have the low 1st gear set in the 904?
No A regular '69 Slant6 Gearset on this 904
What is the rear gear ratio?
4.56
@Rick Covalt, Bring the Shocks, Heck it's worth a try!
Thanks!
PostPosted: Tue May 17, 2011 9:09 pm
The CE shocks are junk. Get a set from Calvert
Agreed!!
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Tue May 17, 2011 11:26 pm
4.56 should be fine. I think the low 1st gear will help also, You can find them in the later lock up transmissions or maybe ebay.
NHRA V/SA Record holder 2009
