It is currently Thu Jun 18, 2026 8:40 am
 Post subject: im very new...
PostPosted: Tue May 17, 2011 5:55 pm
where would i find the drain plug for the engine oil? its for a 68 valiant slant six
PostPosted: Tue May 17, 2011 6:03 pm
on the bottom of the oil pan......
PostPosted: Tue May 17, 2011 6:05 pm
If I remember correctly it should be towards the back on the bottom of the oil pan. It's been awhile since I've been under mine. But it'll be on the bottom of the oil pan.
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Tue May 17, 2011 10:30 pm
Depending on production date, it's either at the bottom rear or at the bottom on the driver's side of the oil pan.
As quickly as you can, go get the three books described in this thread. You need them urgently.
