It is currently Mon Nov 23, 2026 6:18 pm
PostPosted: Sun May 15, 2011 3:26 pm
This probably should be added to the 4-speed article but will post here for people about to do this....
Step 1...make sure you have your current tranny removed, tires blocked, clean flammable debris from under the car. Remove front seat, carpet and carpet underlayment or junk. It should look like pic 1 (1973 Duster here)...Inspect for rust (this can be repaired at the same time if needed).
If you grabbed a junkyard floor hump from a similar vehicle (1973 Dart Sport pictured here), it should fit and you can index it with the seams and contours on your floor pan. If you took a large chunk of tin with the hump, trim as necessary.
Here we are properly set and I notice that I have a nice hole under the go pedal that will also need to be sealed up. If you want to make sure it doesn't shift places for the next stage screw it down in a couple of spots with a #8 tek-screw (self tapping and small)
Once placed, use a black felt tip marker to trace the inside border of the hump, this will be necessary for the proper clearance of the shift rods for either 3 or 4 speed floor shift units.
Next you will want to check the floor pan for the spotwelds unitizing the body to the cross reinforcement, we don't want to nick or cut this (or more welding and bracing will occur. I have circled a few in the fore ground, and you can connect the dots and swing the lines a bit wide
so we can cut around it and see where it is first.
OK, here's the final lay out, we are going to cut the areas toward the front of the car, and toward the rear of the car, using the cross member as the no cut zone. I used a Harbor Freight 4" grinder with cut off wheels, you can use a sawzall or air powered body saw depending on what you have available.
After cutting the two panels out, locate the spot welds (if there are any!) attaching the body to the metal remnant. You can either use a "spot weld cutter" bit, or use the old tin bender method of an oversize drill bit (like 3/8' or 1/2") to cut release the weld (if you use the tin bender trick you drill it unit you see the metal cracking or separating from the weld)...if some of the metal is still sticking use a cold chisel of big screw driver and hammer to tear it away from the crossmember. Once you are done it should look like this:
Clean up the area around the cuts with a grinder or file so you don't get "hooked", vaccuum or blow out the left over metal shavings as well.
Once you get to this point I suggest installing the tranny and linkage.
Check for clearance. If all is well, then you can weld it to the floor pan.
If you are not trained for welding or your handyman buddy won't do it
for a 6 pack of beverage you can screw the hump down with a good hand full of #8 Teks and your drill. If you welded it now's the time to spread the body sealer or caulking to keep water from weeping back in under your carpet...If you didn't weld it, lay a nice bead of caulk or sealer along the mating flange, push the hump into place then screw it down moving from one end to the other alterating sides (like torqueing down a head).
Now it'll be up to you to get the carpet replaced (need a 4 speed carpet with extra material for the hump), put your seat back into place, and install the shift handle, rubber boot and shift bezels.
Good luck on your conversion.
-D.idiot
PostPosted: Mon May 16, 2011 1:03 pm
Car Model: 1965 Barracuda 'S' auto
Excellent pics, I can only comment that Harbor Freight sells a spot weld cutter for like 4 bucks. Well worth it for this little tool.
PostPosted: Sat May 21, 2011 8:30 am
How hard is it to locate the spot welds? Are they fairly obvious?
vm
PostPosted: Sun May 22, 2011 4:38 pm
Wheres the picts of the install.
 Post subject: Easy
PostPosted: Mon May 23, 2011 5:35 pm
Easy, like fallen off a log. :D
If the area is rusty, wire wheel in the area and they show up easily
Rick
PostPosted: Wed May 25, 2011 8:55 am
these are our pics . done on a high desert calif no rust 1968 dodge dart 440/4 speed project. done 2 years ago , on hold
it was a 273 auto roller, I purchased the OME hump off ebay used. set in place sprayed painted an outline, harbar freight cutting wheel/grinder..I plan on having tabs say 6 aound piece so i can have it removable/acess to trans/linkage.
slant six's RULE!
http://www.usajon.com
