It is currently Wed Sep 16, 2026 10:13 pm
PostPosted: Mon May 23, 2011 12:09 pm
I was cleaning my garage this weekend and I found a brand new Clifford X pipe I never used. I am using the Clifford headers going to a Y and then a single out through a flow master 40 series.
My question is, do you think it's cost effective to add this X pipe to my current setup? I have a cam, headwork, weber carb? I was thinking about just throwing the X pipe as close to the headers and then bringing it back to a Y and though my existing muffler, keeping the cost down, and using this part....what do you guys think?
PostPosted: Mon May 23, 2011 12:44 pm
Only use the X if you want dual exhaust.
An X then a Y is a waste of time and will probably hurt performance.
(you'll be adding restrictions and convolutions to the exhaust flow)
PostPosted: Mon May 23, 2011 3:39 pm
Yup, I second what Ed said. That “Yâ€￾ pipe accomplishes the same task an “Xâ€￾ pipe would with duels.
PostPosted: Mon May 23, 2011 5:44 pm
what dia pipe ???? is the X????
PostPosted: Mon May 23, 2011 6:02 pm
emsvitil- that makes sense, I guess the thought of having a shiny new part that hasn't been installed is to much hahah.
Hantayo13- it's the standard Clifford performance one, I'm thinking 2" maybe? Currently I have a single 2.5" from the muffler back
PostPosted: Mon May 23, 2011 6:42 pm
I got an x pipe sitting in my closet as well
Kev
PostPosted: Tue May 24, 2011 10:39 pm
How about this idea: x pipe as close to the headers, then you have two exhaust pipes into a dual inlet single outlet exhaust. Reduce some drone and pick up some performance?
PostPosted: Wed May 25, 2011 12:30 pm
Sounds like a waste i dont think an x pipe would help any drone issue put a different muffler on if you have a drone problem. If you wanna use the x pipe run dual exhaust and throw the y pipe and single stuff away. If you want use the y pipe and put that x pipe away lol.
Kev
PostPosted: Wed May 25, 2011 6:38 pm
if either of those X-pipes are 2 & 1/2 ....i be interrested...hint hint
PostPosted: Wed May 25, 2011 7:02 pm
No dual inlet muffler I've ever seen had as good transition inside as a proper Y-pipe. A dual inlet muffler under the back seat is going to make for too long of primary pipes. The best you can do is to put the Y in the proper place and use a muffler with enough flow capacity.
PostPosted: Fri May 27, 2011 3:47 pm
What about this one? The TF3-Muffler/Y pipe in a shell :shock:
This was made for a slant that should see 8000rpm tho!!!!
Image :D
Two 2" inlets with 3" outlet. This was a special request from a slant racer.
JUST FLIP IT AROUND FOR THE TWO TAIL PIPE LOOK OUT THE BACK!
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
Users browsing this forum: Amazon [Bot], Google [Bot] and 12 guests
