It is currently Mon Nov 23, 2026 6:36 pm
PostPosted: Wed May 25, 2011 6:06 pm
I would like to hear from anyone who has used a Hurst shifter on an overdrive transmission in an A body. What pieces did you use? Where did you get them, etc. I have quite a few parts but have never really been able to make it work, would like to hear from someone who has.
 Post subject: ?
PostPosted: Wed May 25, 2011 6:21 pm
Seymour,
That is what we put in Ryan's Swinger. I thought it was just a standard Competition Plus shifter and standard rods? What's in your Valiant now?
Rick
PostPosted: Wed May 25, 2011 6:50 pm
Every A833OD I've seen came with a Hurst shifter. It's the linkage rods and levers which make or break the installation.
PostPosted: Wed May 25, 2011 6:52 pm
only different is 3-4 lever flipped on trans....have a comp plus hurst in mine... would love to find an old mr gasket 4 speed shifter
 Post subject: +1
PostPosted: Wed May 25, 2011 7:35 pm
Josh is right on.
PostPosted: Thu May 26, 2011 6:57 am
I am using the Inland shifter which is the only one I have ever seen on an OD trans. Which years and models had a Hurst? Rick, did the rods on Ryan's set up come with the Hurst kit or did you have to use the 3-4 rod that came with the transmission?
PostPosted: Thu May 26, 2011 1:57 pm
the inline is made by hurst
PostPosted: Thu May 26, 2011 2:08 pm
'64-'65 A-body w/4-speed had Hurst shifters from factory.
PostPosted: Thu May 26, 2011 3:20 pm
I have a hurst shifter but even after rebuilding the 833od somethings up with the shift linkage it's crunchy and clicky to pull into gear not smooth and feels like i'm doing a lightning bolt pattern to go from 2nd to 3rd.
Kev
PostPosted: Thu May 26, 2011 3:22 pm
Brewers performance has everything needed for a 833OD conversion and parts needed including rearends. www.brewersperformance.com
A little rebellion now and then... is a medicine necessary for the sound health of government. Thomas Jefferson
 Post subject: ?
PostPosted: Thu May 26, 2011 5:28 pm
Seymour,
It has been a long time since I put the 4-speed in the Dart but I am pretty sure I used the factory shifter and rods that came from a 64 Dart GT originally. I am pretty sure I did not purchase anything different for the OD. I had that same shifter and rods in my 65 Valiant first with a non OD 4 speed.
Rick
 Post subject: Yep...
PostPosted: Thu May 26, 2011 6:07 pm
All the 1975-1980 A/F bodies(and trucks to 1987) with A833OD sometimes have the shifter stamped Hurst in small letters, some of the 1978 F-bodies came with the shift stick with the hurst logo stamped in the side on certain vehicles. Inland floor shifters were still used on the A-230 3-spd trannies at that time also.
-D.idiot
