It is currently Mon Oct 19, 2026 9:45 am
PostPosted: Tue Sep 02, 2003 11:25 pm
Well I read a post and someone said they were having ballast resistor problems with their Mopar performance electric ignition.
So I looked into my Catalog and found 3 different resistors depending on ignition.
Point system- use P4529795
Electric ignition with 1/4 ohm coil - P2444641
Electric ignition with 1 ohm coil - P5206436
Basically i am using the last resistor since I am using an Accel Supercoil.
Also would like to plug www.kollerdodge.com for being one of the cheapest dealerships to get Mopar performance parts if of course you order online.
Users browsing this forum: Ahrefs [Bot] and 7 guests
