It is currently Mon Nov 23, 2026 10:05 pm
PostPosted: Mon May 30, 2011 5:45 pm
Somehow I doubt this is common, but I don't know. A friend of mine who used to set IHRA records racing 904 Tranny on a Hemi Dart and a Hemi Cuda says we should throw that in and it will launch me, even without a different torque converter. Any thoughts, thanks. I tend to believe him just due to his experience, but wonder if anybody else is doing it. Thanks for your input.
PostPosted: Mon May 30, 2011 6:42 pm
If you have a record-setting hemi dart like your friend then use his set-up. Others can chime in but IMO 3.77 would give you a huge drop to 2nd gear.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Tue May 31, 2011 9:55 am
I never heard of a 3.77 low first gear for a Mopar 727 / 904 automatic trans... There is a 2.74 low first gear set-up for 904s
PostPosted: Thu Jun 02, 2011 1:48 pm
When you're talking about full-boogy custom race parts (ie aluminum needle bearing 904 guts living behind a full race Hemi) then I would believe someone has a 3.77 ratio- if it gained them a couple hundreths of a second in the 1320.
63 Valiant Wagon
225 - 4 bbl
