It is currently Mon May 18, 2026 8:22 am
 Post subject: Locked out timing?
PostPosted: Tue May 31, 2011 5:41 pm
Anyone running locked out timing and if so how much?
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 31, 2011 5:57 pm
Mine is pretty much locked out. 27* w/no vaccuum.
This is on a race car. Locked timing is not really a good thing on the street. :shock:
PostPosted: Tue May 31, 2011 6:20 pm
Well mine only wants to run/idle at 34*+ locked and not diesel when shut off, AFR reads 12 on heavy accel, 13 on light accel and a touch over 14 at cruise. I was at 8* initial with 24* mech(factory Mallory setting) and no vac. It ran good but idled like crap and fell on it's face from idle and had NO torque. I put it at 30* locked out as a test and went up from there and even at 34* could probably use 2* more. It now idles smooth and doesn't cough and miss after driving on the freeway and best of all doesn't deisel. I was reading other inline boards and guys saying they were as high as 38* locked out on a street driven car. And before its asked, yes cam was degreed to Clifford specs and was straight up as the claimed.
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 31, 2011 6:32 pm
That's at least 1/2 your problem.
PostPosted: Tue May 31, 2011 6:38 pm
So your saying I'm 24*+ off ?
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 31, 2011 9:31 pm
what did you degree the intake center line to? what is the LSA @??
right now mine is at 32 locked cuz it does the same as yours... im going to the track saturday to see what it wants... TNT @ Speedworld on Saturday @ 6pm
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Tue May 31, 2011 10:04 pm
Can you post your camshaft specifications, installed intake centerline and static compression ratio? If these three things are correct or close enough you should find 28-30° total timing to provide best power. Initial timing with a performance cam varies, but is usually 12-16° BTDC. Also, was the damper verified to indicate true TDC?
PostPosted: Tue May 31, 2011 10:19 pm
http://users.hal-pc.org/~bwhitejr/Slant_Six_Cams.pdf
Everything verified same as above( #11 Clifford 95-1152) also as per cam card, lobe sep 110. Static is 9.3:1. Yes damper is true TDC spun both directions. .016 int .018 exh
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 31, 2011 10:48 pm
If that was installed on 110° intake centerline that is why it's lazy and needs a lot of timing.
PostPosted: Tue May 31, 2011 11:08 pm
So should I leave it there or degree it with an offset to a lower intake centerline? Like I said it still feels like it wants more, and won't even miss till about 38* in gear.
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Jun 01, 2011 8:25 am
I would advance the cam 8° (4° at the cam) to a 102° intake centerline. The late intake closing point of 110° ATDC is allowing part of the intake charge to be pushed back out of the cylinder at low engine speeds. This means less air and fuel to burn and a lower dynamic compression ratio. This means less torque/HP. Once the cam timing is changed you should find 12-14° initial ignition timing and 28-30° total timing to work best.
PostPosted: Wed Jun 01, 2011 9:33 am
bingo... 102 is perfect...
PostPosted: Wed Jun 01, 2011 2:58 pm
[quote="Joshua Skinner"]I would advance the cam 8° (4° at the cam) to a 102° intake centerline. quote]
In short building cylinder pressure earlier right? I don't see an 8* crank key so I'm guessing the 4* cam bushing is my only option? I obviously don't know enough about cam timing, I just installed as per cam card instrucions and verified Cliffords numbers. :roll:
Thanks for your patience Josh.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Jun 01, 2011 3:32 pm
Yes, a 4° cam bushing should fix you up if the current intake centerline is 110°. Just don't put it in backwards! :D
PostPosted: Wed Jun 01, 2011 3:38 pm
or get an adjustable timing chain...
what did you put in it for a timing chain?? i ended up getting a JP cuz the autozone double row wore out in 6k miles...
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
