It is currently Tue Oct 13, 2026 4:53 am
PostPosted: Fri Jun 03, 2011 8:54 pm
I was looking at purchasing this running engine/transmission combo on ebay. I thought it might work as a backup for my 64 Dart. It is advertised as being from a 65 Dart but with the blue color I had my doubts. The seller mentioned it had the 3 freeze plugs which would indicate it was a pre-67. Here are a few pics. If someone can let me know if it would be compatible with my 64 and what the value might be I would very much appreciate it.
64 Dart GT - 225
PostPosted: Fri Jun 03, 2011 10:02 pm
Looks to me like a pre-'67 engine dressed for service in a '62-'66 A-body and painted a shade of blue never factory-applied to a Chrysler engine.
PostPosted: Sat Jun 04, 2011 9:50 am
Thanks for the reply. Sounds like it will work. I did notice the exhaust manifold uses the round counterweight.
Will the 65 automatic transmission be compatible with my 64 push button automatic as well?
64 Dart GT - 225
PostPosted: Sat Jun 04, 2011 11:42 am
You would need to swap the '64 valve body into the '65 transmission, then it will be compatible.
PostPosted: Sat Jun 04, 2011 12:43 pm
Thanks again! I think you saved me from a purchase I didn't need to make. The current bid is $105 but no sense in buying another engine if mine is working fine.
64 Dart GT - 225
PostPosted: Sat Jun 04, 2011 5:06 pm
Why not just look up the engine number, then you'll know for certain what you've got.
Olaf.
Aspenized
Users browsing this forum: Bing [Bot] and 8 guests
