It is currently Tue Sep 29, 2026 9:01 am
Post new topic  Reply to topic  [ 58 posts ]  Go to page 1 2 3 4 Next
PostPosted: Wed Jun 01, 2011 9:20 pm
Did the first real pulls with the turbo 68 Dart today at 6psi boost. Pulls pretty hard from 2600 RPM up. Should work great on the track and for putting around. Big smiles on my face for sure...
No major leaks/problems as yet. May need a bigger tire to pull it all the way through the 1/4 mile in 3rd gear. 3.55 gears and 24" tire now. 2200 stall converter should make for easy traction, kinda sucky 60 fts, but easy on all the parts. Good for a boost beginner.
Should be good for travel to Kearney. Spent 45 min in rush hr traffic after leaving Seymour's shop.
More tuning tomorrow. AFR at 10.6-11 and stable under WOT and full boost.
This thing will be really nuts at 12 psi or more.
PostPosted: Wed Jun 01, 2011 9:24 pm
Awesome Lou lets see some pics man sounds like you been secretly tuning :)
Kev
PostPosted: Thu Jun 02, 2011 5:43 am
Cool.
60 foots won't be as bad as you think. It will make a ton of torque down low.
11.02 @ 120.56
Chassis dyno
PostPosted: Thu Jun 02, 2011 6:10 am
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
Years ago a friend had a turbo 202 cube Holden 6, and changed the gears from 3.23, to 3.08. It went better everywhere. Seemed to make the turbo "work"
Richard (aka Fingers)
PostPosted: Thu Jun 02, 2011 11:44 am
Congrats...loooking forward to seeing this hot rod. Later
Ryan
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Thu Jun 02, 2011 4:36 pm
Lou u need some pics I want to see that header u had made
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Thu Jun 02, 2011 8:34 pm
Plenty of pics on my flickr site.
http://www.flickr.com/photos/16910097@N ... 924551471/
No pics there from the running version, but it all looks about the same...
I read the boost on the MS-EFI MAP sensor during a hard pull and it maxed out around 150 kPa, or about 7.5 psi boost. Not the same as the 6 psi spec'ed for the wastegate, but close enough I guess. It feels like a rocket, but I am holding off guessing what it'll turn on the track.
Took my 4 yr old nephew and sister-in-law for a ride after lunch. Little Arthur's smile was bigger than mine...
Launching will be easy. Boost doesn't start coming up until about 2400-2600 RPM at WOT, then it takes off.
One issue is I now have a little miss at idle. Best guess is a wee leaking intake manifold gasket on one cylinder? Cleans up above idle, so I guess it's OK. Any input from the experts here? Will I hole a piston if I keep leaning on it?
Seymour and I worked on the car a little today at his shop - me making brake+whl brng adjustments and swapping wheels/spacers around, and he kindly fabbed a heat shield for the master cyl so I don't melt it down or boil fluid. What a guy!
PostPosted: Fri Jun 03, 2011 1:00 pm
No intercooler eh no meth kit right? Eh 7.5psi i wouldn't think you could hurt it since you got the afr in a good range under wot.
Kev
PostPosted: Sun Jun 05, 2011 5:04 am
:twisted: Very nice set up Lou, minimal plumbing. Looks like the Nitrous racers will be feeling a little more pressure from you now :!: Keep us posted Don.
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Sun Jun 05, 2011 3:12 pm
Spool up that turbo for Good 60's !!!
Cool!
PostPosted: Sun Jun 05, 2011 4:04 pm
Lou are you gonna get a heat shield for the hotside? The one i'm using looks awesome and works awesome I can lightly rest my hand on the turbo with the car running on the hot side with the snail cover. It's a DIY? brand can't remeber it's made of pulvarized lava rock woven into a heat shield lol. When i saw it i was like lava rock oh i want that plus it doesn't look corny like a boxing glove like the other ones i saw on ebay. Just an idea to help keep the toast out of your master cylinder.
http://cgi.ebay.com/ebaymotors/DEI-0101 ... ccessories
Kev
PostPosted: Mon Jun 06, 2011 12:15 pm
Thanks, guys. Kev, thanks for the heatshield link. I may get one a dem!
14.98 @ 95.3 MPH was fastest time with non-optimal mixture and retarded timing. Methinks we can get to the 13s with minimal tweaks and good air. Still gets decent mileage 21-22 MPG for the 1000 mi roundtrip. Better tires and a new limited slip will really help build boost and 60 ft, and 3.23 gears will let us air it out at the top end. With the 3.55s and 24.8" tires, 96-100 MPH is about the max.
PostPosted: Mon Jun 06, 2011 5:57 pm
Badass Lou thats an awesome out of the box time great gas mileage lol i wish i could get that outa my motor with that giant bg demon i gotta figure some trick to pull out of my sleeve for some better mpg.
Just waiting on my header from ceramic coat then i'll be back on the road and to the track pretty soon hopefully.
Kev
PostPosted: Mon Jun 06, 2011 7:30 pm
Sounds great, Kevin. I look forward to hearing about your runs too!
My long-term plan of going to tunable port EFI before turboing seems to have worked perfectly. It was astonishingly easy to get the mixture tuned for 11.5:1 WOT pulls, and mileage. Hard to imagine doing that with a carb - once EFI'ed, can't go back...
I was pretty happy with hitting the 14s with 4400 ft density altitude and conservative tuneup.
Cheers,
PostPosted: Tue Jun 07, 2011 11:42 am
What work is done to the engine lou? cam and what not? What rpm are you getting out of the motor?
Kev
