It is currently Fri Jul 17, 2026 8:08 am
PostPosted: Mon Jun 13, 2011 8:55 am
who makes the best 1/4 mile drag racing intake for a 4 barrel carb?
thinking of going that route..
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Jun 13, 2011 9:21 am
The Offy is better at low RPM and works easier with a stock exhaust manifold. Unless you go big with the cam, compression and head work it's likely to give you better ETs than a Clifford. A 500 CFM Holley 2bbl with an adapter matched to a Super Six 2bbl intake works quite well also and is potentially much cheaper.
PostPosted: Tue Jun 14, 2011 7:15 am
Depends on who you talk to and haw you build your setup. ANY of the 4 bbl setups will work well.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jun 14, 2011 10:52 am
Yep, VERY dependent on motor buildup and desired driving characteristics.
PostPosted: Wed Jun 15, 2011 4:32 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Pretty much any post above is correct. I have seen stock manifolds that were modded to accept four barrel carbs that worked extremely well.
On the drag strip, I don't think any of them are worth that much over another one. This is my OPINION. I do know that the Offenhauser is a great piece for the street. Lots of people like the Clifford for higher horsepower builds.
I am going to use a Weiand on my next motor because it's what I have.
I've seen them run good on other motor's, so why not mine?
I wouldn't fret to much over the intake because the head is the place to spend the coin by far.
Good luck!
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
