It is currently Tue Nov 24, 2026 11:53 am
 Post subject: Id 904 without id
PostPosted: Thu Jun 16, 2011 5:08 am
I have a torqueflite (904) and it is a 64 or a 65, as far as I understand the shifting cables are different for a 64 and a 65 (console) so I would like to know the year of the tranny, any ideas on how to figure out if it is a 64 or 65, I do not have much of the tranny id, most of it is unreadable.
It starts with ?4?6? and ends with 159 1689.
Is there any other way except using the ID to figure it out ?
PostPosted: Thu Jun 16, 2011 12:47 pm
AFAIK, the difference from 64 to 65 was just the shifter, from push button to column shift. The 2-cable (904) trans wasn't changed (anyone please correct me if I'm wrong).
The 727 went from ball & trunion to slip yoke U-joint, & all 66 went to single lever linkage.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Jun 16, 2011 1:01 pm
Valve body differences between lever-shift and button-shift twin-cable transmissions. You can swap the complete valve body to convert one to the other, or if you know what you're doing you can swap just the necessary pieces.
PostPosted: Thu Jun 16, 2011 1:48 pm
It is not possible to use a 64 PB valve body with a 65 shifter. The casting at the end of the manual shift valve bore is solid. The 65 valve body casting in this area is open, allowing the 65 manual valve (which is longer) to protrude out of the casing. A 65 valve body can be used with either the 64 or 65 shifters, by just swaping the manual valve and detent "comb" for the correct year/style shifter.
My 66 Cuda has a 65 trans, with a modified valve body and a push button shifter in a console between the seats.
PostPosted: Thu Jun 16, 2011 2:22 pm
So to find-out which one you have, either pull-off the pan and look at the comb or grab the cable shift "sleeve" and carefully push / pull it and count the clicks.
The 60-64 will have R, N, D, 2, 1 = 5 Clicks and the 65 will have 6. (PRND21)
PostPosted: Thu Jun 16, 2011 2:56 pm
Ok, thanks, it was a 65
So a 64 shift cable will fit a 65 tranny ? (with the exception of different length).
