It is currently Mon Oct 12, 2026 7:57 pm
 Post subject: choice of head
PostPosted: Thu Jun 16, 2011 1:34 pm
I have a 73' engine block and two heads 73 and 80 years. Both in good condition. What is preferable?
1970 Dodge Dart /225
PostPosted: Fri Jun 17, 2011 1:30 pm
You will get differing opinions depending on who answers. Performance-wise, they will have identical potential. 73 has drool tubes so some don't like those for small oil leaks. 80 is a heavier head (few lbs).
PostPosted: Fri Jun 17, 2011 11:53 pm
You can use the extended tip spark plugs with the drool tube heads.
The extended tip plugged engines tend to run smoother.
