It is currently Wed May 20, 2026 10:49 am
PostPosted: Sun Jun 19, 2011 10:13 am
As soon as the Key is on, the units go to the hot position. the in dash is original, the aftermarket is new, the Heat sending unit is new, new radiator, new thermostat, new everything. what did I miss, its all grounded. all the other gauges work. these two just pegged at extreme hot.
PostPosted: Sun Jun 19, 2011 10:35 am
its all grounded.
Yeah, I think the wire to the sending unit is shorted to ground.
 Post subject: will
PostPosted: Sun Jun 19, 2011 10:40 am
will check this. thanxs
PostPosted: Sun Jun 19, 2011 11:33 pm
Your not trying to use the same sending unit for the stock and aftermarket gauge are you?
 Post subject: same
PostPosted: Mon Jun 20, 2011 9:23 am
ah, yes.
PostPosted: Mon Jun 20, 2011 1:43 pm
That won't fly. Each sending unit can only drive one gauge. You may be able to add circuitry to make it work.
Disconnect the sensor from the aftermarket gauge and make sure the stock setup works.
The aftermarket gauges I've seen aren't compatible with the stock sensor. Even if yours is you would need a second one. Once you have the right sender for your aftermarket gauge drill and tap a hole in the thermostat housing for it. Or check for any unused bungs in the top radiator tank. This will only give accurate readings after the thermostat opens.
If you want to monitor the warmup itself... I know some heads have two threaded ports for stock setups that used multiple sensors. See if your head has enough meat in that area for a second hole. Or move the stock sender to the housing and put your aftermarket one in the head.
 Post subject: 2nd
PostPosted: Mon Jun 20, 2011 8:40 pm
thank you for that, couldn't figure it out for nothing, will change it Tuesday morning
 Post subject: plug in back of block
PostPosted: Tue Jun 21, 2011 6:45 pm
there is a plug in the back right of block, can I put a temp unit in there?
PostPosted: Tue Jun 21, 2011 6:57 pm
Generally you want to monitor the water outlet temperature. At the block drain the coolant has not yet circulated through the head so it will read lower than at the water outlet.
PostPosted: Tue Jun 21, 2011 10:11 pm
ok, I have an extra thermostat housing and will tap that. I really cant extend too far into the housing since it will get in the way of the thermostat right?
PostPosted: Wed Jun 22, 2011 4:00 am
You should be good to go on placing thermostat sending unit in thermostat housing as thermostat sits flush with face of head with its valve inside of head. Just double check the length of the sending unit with the depth of housing before drilling.
PostPosted: Wed Jun 22, 2011 6:13 pm
Offset the hole from the center of the thermostat a little to get you slightly more clearance. Sensors are usually NPT thread so make sure you have the right tap.
I've seen adapters that fit inline with the upper hose and have a threaded fitting for the sensor in the middle. Pretty sure it was at summit or jegs but don't quote me on that.
