It is currently Sat Aug 15, 2026 9:53 pm
 Post subject: Dipstick Q
PostPosted: Tue Jun 14, 2011 6:34 am
Contributor
Can anyone tell me if the oil dipstick and tube lengths are the same on a '79 225 as on a '64?
I can't recall which one I have in my newly rebuilt '79 engine, but five quarts of oil with a filter change only come up to the add mark. I'm guessing they are different.
The oil pan is a '64.
PostPosted: Tue Jun 14, 2011 8:04 am
The stick and tube are both different between 1979 and 1964. I would drain the oil, put 4 quarts in the pan and mark the dipstick with a new full mark.
PostPosted: Tue Jun 14, 2011 7:55 pm
Contributor
Thanks for the info. If I can't remember where I hid the other tube, I'll cut this one off to the proper length.
PostPosted: Tue Jun 14, 2011 7:58 pm
Between '64 and '79 the tube length changed dramatically. Chances are you have a dipstick or tube from an engine other than a 1979 model.
PostPosted: Tue Jun 21, 2011 7:31 pm
Contributor
It gets curiouser and curiouser....
I found the '79 dipstick and tube and they are much longer, so the ones installed are from the '64 engine. So, why does the dipstick register a quart low when it didn't with the other engine??? The pan is the same. The only change is a '79 block and head.
Are the dimensions of the block surface where the tube seats different between years?
PostPosted: Tue Jun 21, 2011 7:47 pm
Is the dipstick tube fully seated in the block?
PostPosted: Wed Jun 22, 2011 1:13 am
What year did the dipstick length change, was it in 65 or later ?
PostPosted: Wed Jun 22, 2011 4:34 am
Contributor
Yes...double and triple checked.
PostPosted: Thu Jun 23, 2011 5:34 am
I didnt like long one on my 80 d150 so i cut same amount from both tube and stick....did oil change and remarked stick
keep on roddin'
