It is currently Wed Apr 29, 2026 6:00 pm
 Post subject: shift RPM
PostPosted: Sat Sep 06, 2003 6:25 am
Floored my 904 shifts from 1st to2nd at 3500rpm and 2nd to 3rd at 4000 rpm. Is it normal for the 1st to 2nd shift to be at that much lower rpm?
It accellerates much better when I put it in 1st and shift at 43-4400 at about 45mph. it shifts into 3rd at 76mph.
Thanks!
PostPosted: Sat Sep 06, 2003 8:23 am
Lengthen kickdown rod. This will up the shift points. That sounds about right for a stock /6, but it sucks for performance.
Where in SE Pa are you?
"DW"
If it ain't broke, fix it!
PostPosted: Sat Sep 06, 2003 8:32 am
I live in northeastern montgomery county between allentown and philadelphia.
I'll have to give lengthening the kick diwn a little. thanks!
PostPosted: Sat Sep 06, 2003 9:44 am
Cool, Allentown is my ancestral home... I get up that way sometimes.
"DW"
