It is currently Fri Oct 09, 2026 1:15 am
 Post subject: Seal The Bottom?
PostPosted: Sun Jun 26, 2011 5:20 pm
Wanting to change the timing chain, pan gasket and seals.
Can a slant rear seal be successfully changed with the crank in?
PostPosted: Sun Jun 26, 2011 7:37 pm
Yes, see FSM. Need a soft metal tool to push out top half while rotating crank, or wooden or plastic dowel could work.
I've done it once, and it worked.
Users browsing this forum: DuckDuckGo [Bot] and 19 guests
