It is currently Sun Oct 11, 2026 8:40 pm
 Post subject: valve ajustment blues
PostPosted: Mon Jun 27, 2011 5:11 pm
Hi ya all. Ok I set the valves on my 78 super six and now it acts like its flooded when I start it. Runs great on the road, idles good. I have set valves on many different engines so I'm no stranger to this. Help please! Thanks Adam
PostPosted: Mon Jun 27, 2011 5:25 pm
Can you describe for us the procedure you used to set the valves on this engine?
PostPosted: Mon Jun 27, 2011 7:07 pm
Oops I posted my reply in the wrong spot. Ok I brought each cylinder to TDC on the compression stroke and set intakes on 10 and exhausts on 20. Engine was over night cold.
PostPosted: Mon Jun 27, 2011 7:12 pm
Site Admin
It's likely too tight then. With the OEM cam, if your going to set it cold, add a thousandth or two.
The FSM method is set running, hot.
CJ
PostPosted: Mon Jun 27, 2011 7:33 pm
See valve adjustment procedure.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 21 guests
