It is currently Mon Jun 22, 2026 2:32 pm
PostPosted: Sun Jul 03, 2011 4:52 pm
im just curious as to what gears everybody is running
if you could post the weight of the car
gears
engine output
trap RPM
kinda curious to see
im running
68 dart 3150lbs
3.91's (saving for 4.88's)
215hp
5K
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Jul 03, 2011 5:22 pm
456s,go tru the traps at about 6400,with 28 inch rear tires.I think 488s are too much.Guzzi Mark
PostPosted: Sun Jul 03, 2011 8:08 pm
'66 Valiant
232 ci
3240#
4.56
No tach-shift light set at 6600 and not coming on in high gear
yea i was thinking about that but you also have about 75 more hp and a way lighter car...
its just a set of gears so will find out!
PostPosted: Tue Jul 05, 2011 10:13 pm
3.73s was 904 auto now 833od
Kev
PostPosted: Wed Jul 06, 2011 4:48 am
66 Cuda 3250 lbs
170 engine
either 3.91 with a 23 in tire or 4.56 with a 26 inch tire
about 98 mph
204 rear wheel hp and 354 ft lbs rear wheel torque.
PostPosted: Wed Jul 06, 2011 8:40 am
62 Lancer @ 2700 lbs.
4.30 gearing, 12.70 et @ 104 mph
Hitting 6000 at the finish line w/ 26 inch tires.
(My Hyper-Pak intake likes the lower RPMs...)
I "geared-up" from 4.56 and would go back to that ratio if not spraying N2O
PostPosted: Wed Jul 06, 2011 11:05 am
wow thank you guys! seems like ET vs Trap RPM is all over the place!
it seems that weight is a major factor in gear... i noticed that the lighter cars arn't using more than a 4.30 but the 3K and up are in the 4.56 range...
very interesting...
im just looking at my set up and it seems that 4.56's would not gain me a 600-900 rpm gain from 3.91's...
PostPosted: Wed Jul 06, 2011 9:33 pm
Seymore also runs 456s.Ed,stuff some 488s in it and twist the poop out of it.Then you can re build the motor the way you want and the way you would if you had it to do again.I know your next will bee even better.mark
PostPosted: Wed Jul 06, 2011 10:47 pm
lol... im not blowing up this motor on purpose... i have two other cars to build before i get another slant build from the ground up...
PostPosted: Wed Jul 06, 2011 11:09 pm
see and I have 28 inch tires so 4.56's sound like a safer bet...
 Post subject: gears
PostPosted: Tue Jul 26, 2011 6:35 pm
456 gears
30 inch Hoosiers Drag Slicks
#2700 lb car
WAITING to finally see what it will do in the 1/4 mile...
MINOR set back at Samoa....HAHAHAHA
:D
BIG T
1967 Dart "Six Shooter"
Girlfriend Rhonda... 66 Valiant
Image[/URL]
 Post subject: Re: gears
PostPosted: Tue Jul 26, 2011 9:14 pm
456 gears
#2700 lb car
:D
yea such a bummer!!!
PostPosted: Tue Jul 26, 2011 9:55 pm
I am giveing Terry my 13.00 second back up motor.He went to the trouble to get a coffee mug made at Vegas last year with my run of a life time,000.lite and a 11.96 dial on a 11.97.BEST present I have ever gotten,actually showed up on my birthday.I want to give him back the best present he will hopefully ever get,my spare back up motor that ran a 13.00 at Sacremento 2 years ago.This motor will bee delivered at Sacremento,NO charge,but he will have to follow my guiedlines to make it run like it did in my car.Guzzi Mark
 Post subject: Xmas
PostPosted: Tue Jul 26, 2011 10:30 pm
Wow Mark..... I don't know what to say...... EXCEPT THANK YOU...THANK YOU...THANK YOU! I shall follow your directions to the best of my abilities. Again Thank YOU!
I had to wake Rhonda to make sure I wasn't dreaming. IS IT XMAS? :P
BIG T
Image[/URL]
