It is currently Wed Nov 25, 2026 3:53 am
 Post subject: Aluminum flywheel...
PostPosted: Mon Jun 20, 2011 11:32 pm
I remember seeing the aluminum flywheel subject get thrown around over here a while back...and I DID search but found nothing. Maybe I wasn't holdin my mouth right. did anything ever come of it? Is anyone making an aluminum flywheel that's a direct bolt on? Thanks.
PostPosted: Mon Jun 20, 2011 11:58 pm
Wilcap makes one. I have one with the '68+ large center register I'd part with if you're interested.
PostPosted: Sat Jun 25, 2011 6:21 pm
What is the plus's and the minus's of almoolee-um?
PostPosted: Sun Jun 26, 2011 9:12 am
Less mass allows the engine to rev quicker as the flywheel is storing/absorbing less energy. Generally makes it a little more difficult to get off the line smoothly especially if low gear isn't low enough. Light flywheels are best in light vehicles with ample power and/or good gearing.
PostPosted: Sun Jun 26, 2011 1:29 pm
Also, since a light flywheel stores less energy, you will have to increase idle speed some and/or deal with a "rougher" idle compared to the same eng with an iron flywheel.
That's why many old engines (flathead straight 8's) idled so smoooth- they had big HEAVY flywheels. Again, that's a plus in launching a big heavy car.
An aluminum flywheel would be great on a stripper A-body with a turbo 170 & steep gears.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Wed Jul 06, 2011 10:54 pm
I put an aluminum flywheel in my '65 Coronet street car last time I had the engine out. Of course, it is a 512 inch stroker big-block so it has plenty of torque.
PostPosted: Thu Jul 07, 2011 10:47 am
I have been running one in the '64 Dart for the last 5 yrs. Big cammed engine, so idle is a bit rough anyway. Might be a bit twitchier when letting the clutch out, but I am fine with it.
PostPosted: Fri Jul 08, 2011 5:25 pm
How much weight is saved using aluminum? Do you think it would help in the 1/4 mile? Or is it more beneficial for road racing? I was thinking about it for my dart.
Ryan Covalt
PostPosted: Fri Jul 08, 2011 7:23 pm
It about an 18-20 lb weight savings over most passenger car flywheels. It makes a big difference in how the car accelerates in the lower gears. It's not always the best for drag racing though as a light flywheel doesn't store as much energy to help launch the car.
PostPosted: Sat Jul 09, 2011 10:39 am
Yep, a little harder to launch, but I saw no real difference on the dragstrip. Car revs easier in neutral and should wind up a little quicker on the road course, but hard to tell by seat of the pants.
Al flywheel is 11-12 lbs and a stock iron flywheel is 20-22 lbs, so you save about 10 lbs. V8 (or 11" clutch) flys are about 30 lbs, so bigger savings there.
PostPosted: Mon Jul 11, 2011 11:41 am
Is the aluminium flywheel you have josh sfi approved and are they typically stronger than the stock iron piece? I've been wanting a sfi flhywheel for the turbo motor semi worried of taking my toes out with the new found power. :)
kev
PostPosted: Mon Jul 11, 2011 12:11 pm
This flywheel isn't SFI approved per-se, but it's billet and I believe would pass certification easily if tested. It is much stronger than a cast flywheel. I would contact Wilcap and see what they say about it if you need the SFI sticker. I was going to use this on a high RPM 170 as SCTA/BNI says no cast (Fe or Al) flywheels, but lucked into a billet flywheel with a small center register.
