It is currently Sun Jun 14, 2026 5:18 am
PostPosted: Sun Jul 10, 2011 10:13 pm
Just picked up a Weiand Aluminum Intake (4bbl) for a Slant. What other carbs besides the 8007 Holley 390 are being used? street/strip.
 Post subject: Edelbrock
PostPosted: Mon Jul 11, 2011 3:05 am
500 and 600 Edelbrock's are being used and work very well.
Rick
PostPosted: Tue Jul 12, 2011 6:35 pm
im running a 600 holley double pumper... she runs 14.7's all day, and very streetable...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
 Post subject: Re: Edelbrock
PostPosted: Tue Jul 12, 2011 6:36 pm
Rick
i think im gonna make your signature into a bumper sticker!
PostPosted: Tue Jul 12, 2011 8:36 pm
Autolite 4100 ( 1.08 )
Olaf.
Aspenized
PostPosted: Wed Jul 13, 2011 3:07 am
Go ahead Kid, help yourself!
Rick
PostPosted: Mon Aug 01, 2011 1:19 pm
anyone ever try a #4412 Holley 500 cfm 2 barrell?
PostPosted: Mon Aug 01, 2011 1:55 pm
I have used the Edelbrock 1801 AVS and 1404 AFB carbs (both 500 CFM). The AFB seems a bit better, actually, on a mild motor. Bolt on and go. You'll get some secondary bog with a mild motor.
The 4412 Hly 500 2bbl is great for throttle response and power, even on a mild motor. I have run this carb for the last 19 yrs on about every Slant engine I've owned and it has worked well. VERY simple to install (Mr. Gasket adapter plate) and run on the street and strip. Only downside is it's hard to get perfectly tuned for both best mileage and best power at the same time, but I'm picky... Get one with elec choke.
PostPosted: Tue Aug 02, 2011 10:17 pm
Thanks Lou, I have a 4412 to use. Things are coming together.
I am anxious to install. May go with Lokar cables for throttle & kickdown unless I can fab it all together. Let me know when you send the stuff so I can start dismanteling.
