It is currently Thu Jun 25, 2026 2:47 am
 Post subject: Speedometer cable thread
PostPosted: Fri Jul 15, 2011 6:07 pm
This has probably been discussed but I couldn't find it if it was. Anybody know what the thread is on an A833OD speedometer cable/trans? My truck does not have a speedo, and I want to make sure when I upgrade to a programmable speedo I get a sender that will screw on properly to the trans.
PostPosted: Fri Jul 15, 2011 7:19 pm
You can get an electronic sender that fits directly. My '96 Dakota had one. I know other Dodge trucks use them too. I'd get one from a Pick-N-Pull so you get the gear along with the sender.
PostPosted: Fri Jul 15, 2011 7:30 pm
Thanks! I'm gonna give the P-N-P a shot next off day.
 Post subject: Yep...
PostPosted: Fri Jul 15, 2011 10:14 pm
If you find your pick apart pulls the trannies and trashes the sender or won't allow you to pull that part...you can order An Autometer 5291 or a Summit G-2887-1 for the 50-60 buck range.
Because I'm running a combination on the Hpak Duster that Mopar never intended (4.56 rear gears and 205/70R14 tires), it became necessary to use the Autometer 5291-threading is something like 7/8-18... I ran it to a Autometer digital programmable speedo (use whatever speedo gear is handy in your tranny...just have to drive a couple miles, set the program button and you're golden)...
PostPosted: Sat Jul 16, 2011 11:09 pm
Thanks! That was exactly the info I needed.
