It is currently Wed Jun 24, 2026 11:43 pm
 Post subject: New clutch
PostPosted: Fri Jul 15, 2011 8:55 am
So I got my new clutch and was wondering about the scalloped holes in the pressure plate. They kinda look like they are "torn" at the back.
Should I be worried? I don't want to modify a new part but...
Pics are here
This is a 10" Ram clutches powergrip and the part number is 98729
My '73 "Gold" Duster /6
http://www.cardomain.com/ride/2789359
 Post subject: Yipes!!!
PostPosted: Fri Jul 15, 2011 5:55 pm
I'm not so concerned about the 'pressed' notching on the tabs...as much as I see a 10"Borg and Beck pressure plate, that is known to frag using the stock disc, mated with a puck clutch.... :shock:
You got a scattershield or tranny blanket in case the disc loads the pressure plate and the plate decides to come apart?
PostPosted: Sat Jul 16, 2011 8:24 am
ugh!!!! now you tell me :cry:
Well I didn't know it was a puck style until I opened the box, maybe I'll try it with a stock replacment fiber disc. The B&B plate has bigger springs than the old plate
PostPosted: Sat Jul 16, 2011 9:13 am
It's not like we hid this info from you. We've discussed clutches a lot. Greg Ondayko blew up a stock 10" in his Dart. http://www.slantsix.org/forum/viewtopic ... 07&start=8
PostPosted: Mon Jul 18, 2011 5:55 am
Ok I did see that post, but I thought it was from over-reving... This thing will be lucky if it sees 4200 let alone 6200 RPM...
I'm guessing a stocker would have been ok to use, but this one should hold the turbo just fine, and I didn't want to do it twice...
