It is currently Sun May 10, 2026 6:31 pm
Post new topic  Reply to topic  [ 705 posts ]  Go to page Previous 110 11 12 13 1447 Next
 Post subject: Carb & alternator...
PostPosted: Mon Jul 11, 2011 7:04 am
1. [X] Replace brake line to rear of car
2. [_] Lengthen driveshaft to fit the Ford 8" (4.56 Mini Spool).
3. [/] Either swap in the disc brakes from Street Duster or continue to use the SBP drum brakes - Will use the SBP Drums initially
4. [X] Install fuel cell, lines, pump, etc.
5. [/] Install wiring and gauges (ignition, tach, water, oil...)
6. [X] Buy and install a carb / linkage / gas pedal
7. [/] Install radiator
8. [_] Buy and install trans cooler and lines
9. [_] Install seats and harnesses
10. [/] Polish and reinstall lexan windshields
11. [_] Cover a hole in the driver side floorboard
12. [_] Paint floors and roll bar
13. [X] Install Line Loc
14. [X] Reinstall Driveshaft Loop
15. [X] Clean and organize garage for better productivity/safety :D
16. [_] Buy and install electric water pump
17. [/] Install alternator and crank pulley
18. [X] Bleed brakes
19. [X] Install A/C in garage :D
20. [_] Buy and install fitting for temp gauge
21. [_] Buy and install fitting for oil gauge
22. [_] Buy and install correct radiator hoses and thermostat housing
23. [_] Buy and install fuel line and gauge from regulator to carb
24. [_] Buy and install new battery
25. [_] Install overflow bottle
26. [/] Probably another dozen things I haven't thought of yet! :lol:
I need to find a 2 or 3 groove alternator pulley to get it aligned with the crank pulley.
Stuff in BOLD is an update since last time. The / means the task is only partially completed. Once the task is completed it will change to X.
PostPosted: Mon Jul 11, 2011 12:21 pm
Poser
Looks like ya have some very good help. 8)
 Post subject: I love NAPA! :-)
PostPosted: Tue Jul 12, 2011 5:13 pm
8. [/] Buy and install trans cooler and lines
16. [/] Buy and install electric water pump kit
20. [/] Buy and install fitting for temp gauge
21. [/] Buy and install fitting for oil gauge
22. [/] Buy and install correct radiator hoses and thermostat housing
23. [/] Buy and install fuel line and gauge from regulator to carb
My local NAPA guys hooked me up with pretty much everything I needed today. :D
The couple things that they didn't have they directed me to a local performance shop "Branger's" that also hooked me up. :D
So, now I've got several parts to install. Once the heat index drops back down around 100 or so I'll stop by the garage for some more fun. Heat index today was 116, so I wasn't real motivated to play cars. :shock:
Yes, Wayne the boys can be helpful at times. It's kinda hit or miss, so I take it where I can get it. :lol:
 Post subject: Got some parts put in
PostPosted: Thu Jul 14, 2011 6:38 am
7. [X] Install radiator
20. [X] Buy and install fitting for temp gauge
21. [X] Buy and install fitting for oil gauge
22. [X] Buy and install correct radiator hoses and thermostat housing
23. [X] Buy and install fuel line and gauge from regulator to carb
I spent the evening at the garage last night. I tapped the block for the oil pressure gauge and got that put in along with the temp gauge, radiator, thermostat housing, hoses and fuel line to carb.
I forgot to get a fuel pressure gauge, so I still need to do that. I also over estimated the length of the hose, so it's pretty long. Not that big of a deal though.
The electric water pump kit should be in today.
I looked at how I want to install the trans cooler, but didn't start to mount it yet.
I have two alternators to test and a two groove pulley to put together what I need to get the belt in alignment.
Little by little...
PostPosted: Thu Jul 14, 2011 3:32 pm
SSRN National Champion
Very good progress. The list is getting pretty small.
You have to be feeling good about it now.
Ron
PostPosted: Fri Jul 15, 2011 6:38 am
Hey Ron,
I'm feeling better about it. That's for sure. :D
We have swim meets the next two weekends and Angie has a lot of school work right now, so progress will be a little slower.
I'm still shooting for Knoxville though! My boss just approved my leave requests for the Fridays before Knoxville, Bristol and Clay City. :D
PostPosted: Wed Jul 20, 2011 1:47 pm
I spent the evening at the garage again last night. :D I can't change any of the "/" to "X", but I did get the MSD box, voltage regulator and starter solenoid mounted. I didn't wire them (wires still scare me :lol: ), but I did draw some diagrams (again :roll: ) and make a list of questions.
I picked up a fuel pressure gauge and some fittings. I also had them shorten the braided line while I was there. :wink: As I was fiddling with the fuel line I realized that there was no fuel filter anywhere in the system I took out of the Street Duster. :? I have one that was with the GodsRods Duster to use. I just need to move things around and get some more fittings (and a new filter element :shock: ).
I picked up the electric water pump kit as well. Getting it installed may be another story. :lol:
I had the two alternators tested and removed one of the pulleys to install the two groove pulley, but the I.D. of the pulley was to large. I stopped by an alternator rebuilder this morning to find a 2 groove pulley, but the "starter and alternator guy" was off today, "Come back tomorrow..." :?
Not sure if I can get a "kitchen pass" two days in a row and the swim meet this weekend starts tomorrow! :shock: So I may not get anything more done for about a week.
How do people with race cars manage to get them built and out to a track? I know I'm slow and none too bright, but yeesh! :lol:
PostPosted: Wed Jul 20, 2011 1:54 pm
...How do people with race cars manage to get them built and out to a track? I know I'm slow and none too bright, but yeesh!
It's called "thrashing" or the famous last minute "thrash"...
You work non-stop on the car for days, right before a big race or event, in order to make it there...
It sounds like you need a good "thrash session". :shock:
PostPosted: Wed Jul 20, 2011 3:17 pm
I kinda sorta started one trying to get ready for Elk Creek, but things have stalled somewhat lately.
I spent from 7 pm to 2 am at the garage last night. Granted, the first couple hours were spent weedeating the grass (forest :shock: ) around the garage, trailers and truck. However, I'd say I spent a good 4-5 hours focusing on the Duster and all I got done is what is in that last post above. I spend so much time second guessing myself and making double and triple sure about things that I hardly get anything done.
What I need to do is something like John did with his truck engine removal or what several others have done by inviting friends over that know what they're doing to make some real progress. There just ain't too many Slant 6 / Mopar fellers around these parts that I know good enough to ask.
I'll Git R Dun eventually. :wink:
PostPosted: Wed Jul 20, 2011 3:57 pm
Poser
Who says I know what I'm doing? Should know about the pulley tomorrow morning. I am not crawlin' round the barn in today's heat.
PostPosted: Thu Jul 21, 2011 7:21 am
Hey Wayne,
I wasn't necessarily referring to YOU as knowing what YOU were doing. :lol: I know you're just a "Poser" like me. :wink:
I spent 2-3 hours crawling around in the bushes with a weedeater and a pruner a couple days ago and THEN spent another 4-5 hours working on the Duster. And that was AFTER I spent a good 10 hours at work! :shock: I guess that makes me less of a Poser than you... :P :lol: Now get out there in that barn and find me a 2 groove alternator pulley! :D
 Post subject: 2 groove pulley
PostPosted: Thu Jul 21, 2011 7:40 am
Rob I wish I had known you needed a two groove alternator when there is one in all the parts you bought with the challenger.
PostPosted: Thu Jul 21, 2011 9:47 am
I have a couple of alternators with 2-groovers. You can have a whole alt if you like, just have to figure out transfer... No, I don't want to press a pulley off...
PostPosted: Thu Jul 21, 2011 1:36 pm
Poser
The search begins at 6pm after I drop off the number 1 son at football practice. Since Lou seems to have the part in question, I will see if I can get the pulley pressed off(if I find one) - but will wait for your instructions Drill Sargent Simmons! :lol: :lol: :lol:
PostPosted: Thu Jul 21, 2011 2:55 pm
Who says we ever do?
Your Duster will run before mine ever does. :lol: :lol: :lol:
Daytona is just waiting for time and money to coincide. :oops:
Red car is on the trailer and ready to go though. :D
