It is currently Wed Nov 25, 2026 1:04 pm
PostPosted: Sun Jul 17, 2011 9:07 pm
I'd like to gather some info on what would be involved in swapping from a 904 push button to an A 833 OD in my recently acquired 1960 Plymouth Valiant. Has anyone here done this? Without knowing, I'd guess that the trans will bolt up easy with the correct bell. What has to be done in regards to clutch pedal, clutch MC, and linkages?
Stephan
Stephan Nelle
 Post subject: Yep...
PostPosted: Sun Jul 17, 2011 9:49 pm
Most likely you will be on the search for the parts for a 1960-2, manual tranny car to make the conversion for pedals and linkage. A tranny hump will need to be bought or fabricated.
Best of luck,
PostPosted: Wed Jul 20, 2011 5:18 pm
D. Idiot, is there a wider range of cars to browse for pedal assembly and linkages from? Any leads on where I can find what I am looking for?
Stephan Nelle
 Post subject: Not sure..
PostPosted: Wed Jul 20, 2011 7:18 pm
I'm not sure if pedals from a 63-66 would work...the "bathtub"/Engine bay changed between the years so linkage is usually a 60-62,63-66,67+ type thing...
